Home » Modeling » M2T (model-to-text transformation) » difference between 'transform' and 'deployedTransforms' extension points
difference between 'transform' and 'deployedTransforms' extension points [message #43090] Fri, 14 March 2008 11:21 Go to next message
Felix Dorner is currently offline Felix Dorner
Hey, I am a plugin-newbie so if you have general comments feel free..
I have a single plugin that does realize a jet transformation. In my
plugin I also have an action that executes that transformation on a
selected file. Until now, I just used the "transform" extension point,
and in my action I call JET2Platform.tranform...(mypluginID,...)
I now see, that "clients should not use this extension point". As for
now my approach works fine, so why should I not use it? Should I switch
to use the "deployedTransforms" exension point? What is the difference?
Felix
Re: difference between 'transform' and 'deployedTransforms' extension points [message #43643 is a reply to message #43090] Wed, 26 March 2008 10:15 Go to previous message
Paul Elder is currently offline Paul Elder
Felix:
The transform extension point registers information about your
transformation to the JET runtime. It is necessary to successfully load and
execute your transformation.
The deployedTransforms extension point registers a JAR (containing an
exported JET transformation project using the Export deployable plug-ins
wizard). You do not need to use this. In many cases, just deploying your JET
project as a normal plug-in is all you need.
Paul
"Felix Dorner" <felix_do@web.de> wrote in message
news:fre54q$b34$1@build.eclipse.org...
> selected file. Until now, I just used the "transform" extension point, and
> I now see, that "clients should not use this extension point". As for now
> my approach works fine, so why should I not use it? Should I switch to use
> Felix
Previous Topic:UserRegion in non Java artifacts?
Next Topic:UserRegion Does not work... Please help
Current Time: Fri May 24 08:05:25 EDT 2013
Powered by FUDForum. Page generated in 0.01579 seconds
