Home » Modeling » M2T (model-to-text transformation) » Re: Jet Editor and Argument variable
| Re: Jet Editor and Argument variable [message #38424] |
Thu, 03 January 2008 14:08  |
Ian,
I have similar problems in trying to use the JET editor for EMF's
templates. The older one used to work. It's best to ask about this on
the M2T newsgroup which I added to the "to" list of the reply. EMF's
templates rely on referring to "stringBuffer" as well, and that's not
working either. :-(
Ian Bull wrote:
> Hi all,
> I just tried the EMFT Jet editor for editing a javajet file. I have
> done very little JET work before, but I ran through the tutorials on
> Developer works and it seems pretty powerful.
> I use the arguments variable (the one passed to generate method).
> However, the JET editor complains a bit about this:
> <%@ jet
> package="com.ibm.pdc.example.jet.gen"
> class="GenDAO"
> skeleton="custom.skeleton"
> imports="java.util.* "
> <% String user = (String)argument; %>
> It complains because "argument cannot be resolved".
> Is there an easy way to get around this error message?
> Cheers,
> Ian
| Re: Jet Editor and Argument variable [message #38456 is a reply to message #38424] |
Thu, 03 January 2008 17:50   |
Originally posted by: irbull.cs.uvic.ca
Also, it seems that when I open a file using the EMFT Jet Editor, it
automatically compiles my template using JET2 (even though it is a Jet1
template). If I close the editor, and run the "compile template" by
hand, then it works.
Is there a setting to say which Jet Editor I wish to use?
cheers,
ian
Ed Merks wrote:
> Ian,
> working either. :-(
> Ian Bull wrote:
>> Hi all,
>> <%@ jet
>> class="GenDAO"
>> Cheers,
>> Ian
| Re: Jet Editor and Argument variable [message #38555 is a reply to message #38456] |
Fri, 04 January 2008 13:22   |
I think I may have figured it out.
In preferences (EMFT JET Transformations -> Compiler options) I had JET2
selected. If I change this to JET1, the editor seems to work (at least
for the arguments). Hopefully that works for you too Ed.
Ian
> cheers,
> ian
> Ed Merks wrote:
>> Ian,
>> on the M2T newsgroup which I added to the "to" list of the reply.
>> EMF's templates rely on referring to "stringBuffer" as well, and
>> that's not working either. :-(
>> Ian Bull wrote:
>>> Hi all,
>>> <%@ jet
>>> class="GenDAO"
>>> Cheers,
>>> Ian
| Re: Jet Editor and Argument variable [message #38588 is a reply to message #38555] |
Sat, 05 January 2008 10:31   |
Ian,
I would have never guessed. That did the trick though. Thanks!
> JET2 selected. If I change this to JET1, the editor seems to work (at
> least for the arguments). Hopefully that works for you too Ed.
> Cheers,
> Ian
>> Jet1 template). If I close the editor, and run the "compile
>> template" by hand, then it works.
>> cheers,
>> ian
>> Ed Merks wrote:
>>> Ian,
>>> Ian Bull wrote:
>>>> Hi all,
>>>> have done very little JET work before, but I ran through the
>>>> tutorials on Developer works and it seems pretty powerful.
>>>> <%@ jet
>>>> class="GenDAO"
>>>> Cheers,
>>>> Ian
| Re: Jet Editor and Argument variable [message #38712 is a reply to message #38588] |
Mon, 07 January 2008 09:29   |
Paul Elder Messages: 844 Registered: July 2009 |
Ed & Ian:
I'll have Joel take a look at this. IMHO, you shouldn't have to go through
such gyrations.
Paul
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:flo7p6$b5b$1@build.eclipse.org...
> Ian,
>> Cheers,
>> Ian
>>> cheers,
>>> ian
>>> Ed Merks wrote:
>>>> Ian,
>>>> working either. :-(
>>>> Ian Bull wrote:
>>>>> Hi all,
>>>>> <%@ jet
>>>>> class="GenDAO"
>>>>> Cheers,
>>>>> Ian
Current Time: Tue May 21 06:42:55 EDT 2013
Powered by FUDForum. Page generated in 0.08511 seconds
