Home » Modeling » EMF » How to extract the corresponding XML for an EObject.
How to extract the corresponding XML for an EObject. [message #423306] Fri, 26 September 2008 13:56 Go to next message
drew frantz is currently offline drew frantz
ie. I am rendering the XML fragment for an EObject so that it be printed and
or passed to other clinets in a string. Is there a way to do this?
Re: How to extract the corresponding XML for an EObject. [message #423307 is a reply to message #423306] Fri, 26 September 2008 14:49 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
--------------010409070700090100060102
Drew,
You could use
* Write only the subtree starting at the specified list of EObjects,
* which must be objects contained by the resource.
String OPTION_ROOT_OBJECTS = "ROOT_OBJECTS";
<html>
<head>
</head>
Drew,<br>
<br>
You could use <small><br>
</small>
<blockquote><small>&nbsp; /**</small><br>
<small>&nbsp;&nbsp; * Write only the subtree starting at the specified list of
EObjects, </small><br>
<small>&nbsp;&nbsp; * which must be objects contained by the resource.</small><br>
<small>&nbsp;&nbsp; */</small><br>
<small>&nbsp; String OPTION_ROOT_OBJECTS = "ROOT_OBJECTS";</small><br>
</blockquote>
<br>
drew wrote:
<blockquote cite="mid:gbj7no$8cr$1@build.eclipse.org" type="cite">
<pre wrap="">ie. I am rendering the XML fragment for an EObject so that it be printed and
</pre>
</blockquote>
</body>
</html>
--------------010409070700090100060102--
Re: How to extract the corresponding XML for an EObject. [message #423353 is a reply to message #423307] Mon, 29 September 2008 08:31 Go to previous messageGo to next message
This only seems to work if the EObject is self-contained (has no references
to other eobjects) , if the EObject has a field that is a reference to
another Eobject then I get an exception when the resource gets saved.
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: The object
'.......' is not contained in a resource.
Here is the snippet I use to save the resource to a string, maybe there is
another option that should be specified?
///////////snip
List theList = new ArrayList();
theList.add(theType);
Map options = new HashMap();
options.put(XMLResource.OPTION_ENCODING, "UTF-8"); //$NON-NLS-1$
options.put(XMLResource.OPTION_ROOT_OBJECTS, theList);
StringWriter o = new StringWriter();
XMLResource theRes = (XMLResource) theType.eResource();
theRes.save(o, options);
String s = o.getBuffer().toString();
System.out.println(s);
"Ed Merks" <Ed.Merks@gmail.com> wrote in message
news:gbjasb$tmq$1@build.eclipse.org...
Drew,
You could use
Re: How to extract the corresponding XML for an EObject. [message #423354 is a reply to message #423353] Mon, 29 September 2008 08:37 Go to previous message
--------------040109020307000808030205
Drew,
Comments below.
Well yes, if you want someone else to read it, it won't do them a lot of
good if there are references to other things you don't send to them.
> ///////////snip
You could use this option to discard the dangling references:
* This can be one of "THROW", "DISCARD", "RECORD", where "THROW"
is the default.
String OPTION_PROCESS_DANGLING_HREF =
"PROCESS_DANGLING_HREF";
String OPTION_PROCESS_DANGLING_HREF_THROW = "THROW";
String OPTION_PROCESS_DANGLING_HREF_DISCARD = "DISCARD";
String OPTION_PROCESS_DANGLING_HREF_RECORD = "RECORD";
> Drew,
> You could use
<html>
<head>
</head>
Drew,<br>
<br>
Comments below.<br>
<br>
drew wrote:
<blockquote cite="mid:gbqhrs$h4r$1@build.eclipse.org" type="cite">
<pre wrap="">This only seems to work if the EObject is self-contained (has no references
</pre>
</blockquote>
of good if there are references to other things you don't send to them.<br>
<pre wrap="">
///////////snip
</pre>
</blockquote>
You could use this option to discard the dangling references:<small><br>
</small>
<blockquote><small>&nbsp;&nbsp; * This can be one of "THROW", "DISCARD",
"RECORD", where "THROW" is the default.</small><br>
<small>&nbsp; String OPTION_PROCESS_DANGLING_HREF&nbsp;&nbsp;&nbsp;&a mp;nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; =
"PROCESS_DANGLING_HREF";</small><br>
<small>&nbsp; String OPTION_PROCESS_DANGLING_HREF_THROW&nbsp;&nbsp;&n bsp; = "THROW";</small><br>
<small>&nbsp; String OPTION_PROCESS_DANGLING_HREF_DISCARD&nbsp; = "DISCARD";</small><br>
<small>&nbsp; String OPTION_PROCESS_DANGLING_HREF_RECORD&nbsp;&nbsp; = "RECORD";</small><br>
</blockquote>
<pre wrap="">
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:Ed.Merks@gmail.com">&lt;Ed.Merks@gmail.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:gbjasb$tmq$1@build.eclipse.org">news:gbjasb$tmq$1@build.eclipse.org</a>...
Drew,
You could use
</pre>
</blockquote>
</body>
</html>
--------------040109020307000808030205--
Previous Topic:Wrapping character values using SimleAnyType
Next Topic:CDO resourceSet
Current Time: Thu May 23 02:51:23 EDT 2013
Powered by FUDForum. Page generated in 0.01544 seconds
