Home » Eclipse Projects » SWTBot » install document
install document [message #41104] Mon, 29 June 2009 14:09 Go to next message
lalitha Missing name is currently offline lalitha Missing name
I am having a tough time installing swtbot in my eclipse environment and
getting a sample program to work.
Is there a document that has step by step instructions on all the zip
files that are required, and instructions on where the jar files need to
be copied to in the Eclipse plugin development environment?
Any help will be appreciated.
Re: install document [message #41135 is a reply to message #41104] Tue, 30 June 2009 00:03 Go to previous messageGo to next message
Ketan Padegaonkar is currently offline Ketan Padegaonkar
There's a user guide linked from the home page:
http://wiki.eclipse.org/SWTBot/UsersGuide
Ketan
http://studios.thoughtworks.com/twist | http://twitter.com/ketanpkr
On 29/6/09 23:39, lalitha wrote:
Re: install document [message #41165 is a reply to message #41135] Tue, 30 June 2009 02:19 Go to previous messageGo to next message
Pierre-Charles David is currently offline Pierre-Charles David
Member
Personaly I found that document rather confusing. It talks about .releng
projects, dependencies not available and to be added manually, patched
versions of Eclipse frameworks, building update sites... All things
which seem targeted to SWTBot developers and not plain users.
I followed the following steps to test it under 3.4:
1. Add the update site URL provided on
http://www.eclipse.org/swtbot/downloads.php for your target (3.4 or 3.5)
2. From that update site, install both features "SWTBot SWT Features"
and "SWTBot Eclipse Features". Restart Eclipse.
3. To check if it is properly installed, open the "Run Configurations"
dialog. You should have a new category called "SWTBot Test".
4. Create a new plug-in projet to do a quick test.
5. Add the following dependencies:
org.eclipse.swtbot.swt.finder
org.eclipse.swtbot.eclipse.finder
org.junit4
6. Copy/paste the TestSampleDialog class from
http://wiki.eclipse.org/SWTBot/UsersGuide in that plug-in. There are
some deprecation warnings, but it should compile.
7. Select the TestSampleDialog class in the Package Explorer, and do a
"Run as > SWTBot Test". After a while you should see the new Eclipse
runtime opening and automatically creating a new Java project from the
wizard.
Re: install document [message #41195 is a reply to message #41165] Tue, 30 June 2009 02:25 Go to previous messageGo to next message
Point noted :) The initial guide was aimed at users like yourself. Seems
it was edited for people wanting to build swtbot themselves. I'll move
the content around.
A previous snapshot of the userguide[1] may help (although it is still a
bit outdated). The changes being to the namespace of the code and the
- org.eclipse.swtbot.swt.finder
- org.eclipse.swtbot.eclipse.finder
- org.hamcrest
- org.junit4
- org.eclipse.swtbot.junit4_x
- org.apache.log4j
Also there's a tutorial[2] that I should link to from the home page.
[1] - http://wiki.eclipse.org/index.php?title=SWTBot/UsersGuide&am p;oldid=150740
[2] - http://download.eclipse.org/technology/swtbot/docs/eclipseco n2009/
Ketan
Re: install document [message #41289 is a reply to message #41195] Tue, 30 June 2009 14:55 Go to previous messageGo to next message
Guys,
Thanks for your suggestions, I was able to run the test and am now looking
into how I can incorporate it into our UI testing.
L
Re: install document [message #42318 is a reply to message #41195] Wed, 08 July 2009 12:04 Go to previous message
Derek  is currently offline Derek
Member
Thanks! The revised Users Guide is definitely more clear and helpful now :)
Previous Topic:SWTBot launch configuration obsolete?
Next Topic:help with swing / rcp application testing
Current Time: Sun May 19 06:53:31 EDT 2013
Powered by FUDForum. Page generated in 0.05617 seconds
