| AdapterFactory not getting invoked. ? [message #414624] |
Thu, 15 November 2007 10:38  |
biju Messages: 13 Registered: July 2009 |
Junior Member |
Hi All,
I have created an AdapterFactory(an impl of IAdapterFactory), to
adapt my Eobject and registered it using the extension point, but the
AdapterFactory#getAdapter() is not getting called when I call for
adapter as follows:
1.
EcoreUtil.getRegisteredAdapter(resource,TimeBarNode.class)
2. Registered Factory as follows:
<extension point="org.eclipse.core.runtime.adapters">
<factory
adaptableType="com.intsolvers.scheduling.schedule.impl.TaskResourceImpl "
class=" com.intsolvers.scheduling.factories.TaskResourceAdapterFacto ry ">
<adapter
type="de.jaret.util.ui.timebars.model.TimeBarNode">
</adapter>
</factory>
3. Implemented IAdaptable on my EObject and my getAdapter method id as
follows:
public Object getAdapter(Class adapter) {
return Platform.getAdapterManager().getAdapter(this, adapter);
Any Idea on what might be wrong..?
Thanks, ;) Biju
| Re: AdapterFactory not getting invoked. ? [message #414627 is a reply to message #414624] |
Thu, 15 November 2007 10:52   |
Ed Merks Messages: 24562 Registered: July 2009 |
Biju,
Comments below.
biju wrote:
> Hi All,
> adapter as follows:
> 1.
There's no direct relationship between EMF's Adapter/AdapterFactory APIs
and the platforms IAdatper/IAdapterFactory APIs. The designs are
significantly different even though they have very similar names. For
the above to work, the containing resource set's getAdapterFactories
would need to contain an EMF AdapterFactory that could create an adapter
for this type.
> <factory
> <adapter
> </adapter>
> </factory>
> follows:
If your objects implement IAdaptable then you'd cast to that interface
and call getAdapter directly. And instead of doing what you're doing in
1, you'd do what you see in the body of this method instead.
> Thanks, ;) Biju
| Re: AdapterFactory not getting invoked. ? [message #414685 is a reply to message #414627] |
Fri, 16 November 2007 07:48  |
Junior Member |
Hi Ed Merks,
Thanks for your reply, Its working
I changed it as you said, inststead of
"EcoreUtil.getRegisteredAdapter(resource,TimeBarNode.class)" i called
resource.getAdapter(TimeBarNode.class);.
Thanks for your help :) Biju
Ed Merks wrote:
> Biju,
> Comments below.
> biju wrote:
>> Hi All,
>> adapter as follows:
>> 1.
> for this type.
>> <factory
>> <adapter
>> </adapter>
>> </factory>
>> follows:
>> Thanks, ;) Biju
FUDForum. Page generated in 0.01955 seconds
