Home » Eclipse Projects » Mylyn » Task Synchronization
Task Synchronization [message #40266] Thu, 03 January 2008 05:38 Go to next message
Christian Stellwag is currently offline Christian Stellwag
Member
using Mylyn for my tasks in a DB-based application, I wrote my own
connector and TaskEditor for it following the instructions on Mylyn
Integrator Reference and looking at TracConnector. I tried to avoid
TaskData (and -Handler) because I always have DB-connection open.
Now I'm stuck with the following problems (I will describe only briefly
the cirumstances in order to keep it short):
1) Calling TaskList.notifyTaskChanged(), some attribute changes in
TaskEditor are not reflected in TaskList (Summary is, Priority-! is not).
? How can I asure/force these changes to be shown in TaskList, do I have
to set some dirty-attribute?
2) When changing task attributes in TaskListView with context menue (e.g.
Schedule->...) these changes are kept local but not forwarded/stored into
Database. When opening TaskEditor, task is read from DB again and changes
get lost.
? Is Synchronization only one-way DB->local?
Do I have to store these changes manually?
Where do I best hook my code (e.g. as ChangeListener in TaskList?)
Or do I get this automatically if I implement TaskDataHandler and use
TaskData?
btw: updateOfflineState (AbstractRepositoryConnector) mentioned in
Mylyn_Integrator_Reference section Implementing core extension points
doesn't exist (anymore).
I would be very thankful for any Tipp that improves my understanding of
Mylyn and helps me solving these issues.
Chris
Re: Task Synchronization [message #41038 is a reply to message #40266] Fri, 11 January 2008 19:21 Go to previous message
Eclipse User
Originally posted by: beatmik.acm.org
Hi Chris,
Please send this question to the mylyn-integrators list.
http://www.eclipse.org/mylyn/community/
Mik
Chris wrote:
> (e.g. Schedule->...) these changes are kept local but not
> forwarded/stored into Database. When opening TaskEditor, task is read
> from DB again and changes get lost. ? Is Synchronization only one-way
> DB->local?
> Do I have to store these changes manually? Where do I best hook my code
> TaskData?
> Chris
Re: Task Synchronization [message #586947 is a reply to message #40266] Fri, 11 January 2008 19:21 Go to previous message
Mik Kersten is currently offline Mik Kersten
Hi Chris,
Mik
Chris wrote:
> DB->local?
> TaskData?
> Chris
Previous Topic:Problems updating from Mylyn 2.1 to 2.2 using Update Manager
Next Topic:Access restriction: The type Browser is not accessible due to restriction on required library
Current Time: Sat May 18 21:46:23 EDT 2013
Powered by FUDForum. Page generated in 0.02147 seconds
