Do you know whether the BPMN-SVN-location has been changed or how long it
will be unreachable?
Concerning the Diagram Code I'd like to know if it is possible to generate
the original Diagram Code using the bpmn.gen-file from SVN (in the
trunk-folder), because every attempt failed.
Sven Kühner wrote:
> hi,
> it will be unreachable?
Look at this page for the new location of the code: http://www.eclipse.org/bpmn/source_code.php
> generate the original Diagram Code using the bpmn.gen-file from SVN (in
> the trunk-folder), because every attempt failed.
It is clearly not recommended. This code has been heavily modified and
it seems we did not flag all the changes as @generated not.
> Many thanks in advance,
> Sven Kühner
