| don't see the bugzilla content [message #40327] |
Thu, 03 January 2008 09:03  |
Originally posted by: albrecht321.yahoo.de
I tried the mylyn/eclipse 3.3 installation with the bugzilla 2.22.
When I use "validate settings", I get the responce that "Authentication cedentials are valid".
But when I try to get generate a query I get an empty mask.
Has anyone an tip for me ?
| Re: don't see the bugzilla content [message #40788 is a reply to message #40327] |
Thu, 10 January 2008 21:16  |
Originally posted by: rob.elves.eclipse.org
Andreas,
Some quick debugging steps:
1) Ensure the proper repository version is selected in your Task
Repository configuration: Task Repositories (View) -> right+click the
repository -> Properties
2) Also ensure that your repository is returning the proper data by
pointing your browser to <your-repository-url>/show_bug.cgi?id=1&ctype=xml
3) Check if you are able to execute a query via the Search (menu) >
Search... > Task Search page?
More available at:
http://wiki.eclipse.org/index.php/Mylyn_FAQ#Bugzilla_Connect or
-Rob
Andreas wrote:
| Re: don't see the bugzilla content [message #586848 is a reply to message #40327] |
Robert Elves Messages: 87 Registered: July 2009 |
Member |
Andreas,
More available at:
-Rob
Andreas wrote:
FUDForum. Page generated in 0.01779 seconds
