Home » Modeling » EMF » Attribute default value
Attribute default value [message #407198] Sat, 17 February 2007 13:59 Go to next message
Guillaume Brocard is currently offline Guillaume Brocard
is there any way not to have a default value generated for an attribute ?
For instance, instead of generated code :
* The default value of the '{@link #getId() <em>Id</em>}' attribute.
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @see #getId()
* @generated
* @ordered
protected static final String ID_EDEFAULT = null;
* The cached value of the '{@link #getId() <em>Id</em>}' attribute.
* @see #getId()
* @generated
* @ordered
protected String id = ID_EDEFAULT;
I would have liked a simple :
protected String id;
Even if it does not seem different at first glance, it makes a huge
difference when using a custom root class for generated java class,
especially when trying to fill-up attributes in root class constructor
(using polymorphism on generated operations).
Thanks in advance,
Guillaume.
Re: Attribute default value [message #407201 is a reply to message #407198] Sat, 17 February 2007 14:20 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
Guillaume,
No, there's no support for that, at least not yet. Given that the
constructor can change the initial value, why does it make a huge
difference to not have these "default" defaults?
Guillaume wrote:
> * @see #getId()
> * @generated
> * @ordered
> * @see #getId()
> * @generated
> * @ordered
> Thanks in advance,
> Guillaume.
Re: Attribute default value [message #407205 is a reply to message #407201] Sun, 18 February 2007 07:13 Go to previous messageGo to next message
Ed,
I'll try to explain the situation as clearly as possible.
We had experienced problems with JMerge when developing our data model
using EMF. So we decided to be independent from generated code, separating
hand-coded source folder from generated one.
But we still needed services directly on top of the model.
So we introduced an EMF root class called ModelElement (extending
EObjectImpl to remain consistent).
Moreover, we also experienced difficulties with auto-generated element id
when using provided xml persistence (with several files on disk). So we
introduced a ModelElementWithId top class in our model (all others
extending the latter), which provides EMF with an "ID" tagged attribute
(named id :)).
Eventually, we're having following structure : ModelElement (hand-coded)
<|---- ModelElementWithId (generated).
EMF is generating setId() and getId() methods automatically, which is
great. But also the quoted piece of code about id default value.
But, to go on with our goal, generating an id is to be done in
ModelElement (since it's not subject to JMerge). So ModelElement is
providing with abstract method : public void setId(String ..) (implemented
here by ModelElementWithIdImpl) and a concrete method : protected String
generateId().
And ModelElement constructor implementation does look like :
* Constructor.
public ModelElement() {
// Set id at construction time.
setId(generateId());
It seems to be the solution. But ModelElementWithIdImpl generated code :
* @see #getId()
* @generated
* @ordered
* @see #getId()
* @generated
* @ordered
* @generated
protected ModelElementWithIdImpl() {
super();
just erases our generated id with ID_EDEFAULT after exiting its
constructor (default value being executed at this time by java).
We used AspectJ to set the id after initialization of ModelElementWithId.
It worked as intended, but we are now facing a new bug, that is so weird
that we decide to get rid of AspectJ (for testing purposes). And now we
are unable to provide a generated unique id for any model element, and be
independent of generated code at the same time.
Removing ID_EDEFAULT from id declaration line just put things into working
state again, but that relies on JMerge capabilities (as modifying
ModelElementWithIdImpl constructor), which we vowed at first not to use :).
And that's the end of the story, and I hope it helps understanding my
original question.
Guillaume.
Ed Merks wrote:
> Guillaume,
> Guillaume wrote:
>> * @see #getId()
>> * @generated
>> * @ordered
>> * @see #getId()
>> * @generated
>> * @ordered
>> Thanks in advance,
>> Guillaume.
Re: Attribute default value [message #407209 is a reply to message #407205] Sun, 18 February 2007 08:36 Go to previous messageGo to next message
Guillaume,
Comments below.
Guillaume wrote:
> Ed,
> separating hand-coded source folder from generated one.
What kind of problems? We use it ourselves for the development of all
our models and of course many other people use it as well, so any
serious problems I would want to know about and fix.
> id when using provided xml persistence (with several files on disk).
> So we introduced a ModelElementWithId top class in our model (all
> others extending the latter), which provides EMF with an "ID" tagged
> attribute (named id :)).
What kind of problems did you have with auto-generated IDs? UML2 uses
them extensively and hit's used extensively in IBM's products...
> (hand-coded) <|---- ModelElementWithId (generated). EMF is generating
> setId() and getId() methods automatically, which is great. But also
> (implemented here by ModelElementWithIdImpl) and a concrete method :
> protected String generateId().
> * Constructor.
This seems like a bad idea because you will generate an ID during
copying or when creating instances being deserialized and in those
cases, that generated ID will quickly be overwritten by the
copied/deserialized ID.
> * @see #getId()
> * @generated
> * @ordered
> * @see #getId()
> * @generated
> * @ordered
> * @generated
> super();
I see. But as I said, I don't think generating an ID in the constructor
is a good design approach. It would seem better to generate the ID on
demand by overriding getID to return one rather than null.
> ModelElementWithId. It worked as intended, but we are now facing a new
> bug, that is so weird that we decide to get rid of AspectJ (for
> testing purposes). And now we are unable to provide a generated unique
> id for any model element, and be independent of generated code at the
> same time.
> working state again, but that relies on JMerge capabilities (as
> modifying ModelElementWithIdImpl constructor), which we vowed at first
> not to use :).
I really think modifying generated code should be fine and is certainly
done by many many clients.
> original question.
In, 2.3.0, GenFeature has a hasEDefault method that's already used to
guard the generation of the EDefaults, so perhaps we could add a
persistent setting to GenFeature so that the value of hasEDefault can be
explicitly turned off on a feature by feature basis. If you open a
feature request, we'll consider that. The reason I thought you'd give
for wanting this I had thought would be related to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=147952; it actually has a
performance impact to initialize to null rather than just leaving the
field in the Java default state. But you current ID initialization
approach has a much worse performance impact, so you should rethink it...
> Guillaume.
> Ed Merks wrote:
>> Guillaume,
>> Guillaume wrote:
>>> Hi,
>>> attribute ?
>>> * @see #getId()
>>> * @generated
>>> * @ordered
>>> * @see #getId()
>>> * @generated
>>> * @ordered
>>> constructor (using polymorphism on generated operations).
>>> Thanks in advance,
>>> Guillaume.
Re: Attribute default value [message #407223 is a reply to message #407209] Mon, 19 February 2007 02:42 Go to previous messageGo to next message
Hi Ed,
thanks for your answers.
You are certainly right about the performance issue.
Again, we used this approach so as to remain independent.
I'll try overriding getId() directly. Still I'm not very found of this
solution, for it forces us to have generated classes in version of
control, and it makes it a bit harder for an external coder to generate
the whole product. But it can be explained in an accompaning document.
As for your bug request, I did not mention it (our model is not really big
so far), but I do agree.
Finally, for the feature request, I'll find it hard justifying it with our
example (which is quite unsatisfying, and about to be changed accordingly
to your comments).
Again, thanks a lot for your swiftness.
Guillaume
PS : for merge issues, it was due to non-deletion of no-longer-designed
classes (making it hard to sort out generated classes from no-longer
ones). For id issues, I'll try to suppress the ID tag on id attribute, and
see what happens.
Ed Merks wrote:
> Guillaume,
> Comments below.
> Guillaume wrote:
>> Ed,
>> * Constructor.
>> * @see #getId()
>> * @generated
>> * @ordered
>> * @see #getId()
>> * @generated
>> * @ordered
>> * @generated
>> super();
>> same time.
>> not to use :).
>> original question.
>> Guillaume.
>> Ed Merks wrote:
>>> Guillaume,
>>> Guillaume wrote:
>>>> Hi,
>>>> attribute ?
>>>> * @see #getId()
>>>> * @generated
>>>> * @ordered
>>>> * @see #getId()
>>>> * @generated
>>>> * @ordered
>>>> Thanks in advance,
>>>> Guillaume.
Re: Attribute default value [message #407225 is a reply to message #407223] Mon, 19 February 2007 07:30 Go to previous messageGo to next message
Guillaume,
I would personally find it very frustrating to have a repository that
contains code which is not complete (and cannot compile) until you run a
tool to generate the things needed to make it complete. We certainly
commit all our code to CVS and I'm pretty sure most clients take that
approach. I don't see how committing the code makes it harder for
anyone to generate a whole product; in fact, as I said, I think it makes
it easier by not forcing other users to generate the whole product.
People have requested features for far thinner reasons. Since
generating an EDEFAULT that isn't needed has a performance cost, that
fact alone makes it reasonable to request a feature in order to
eliminate a cost when it's not needed. It's quite a trivial thing to
implement. I.e., I can imagine getting it done in far less than an hour
because mostly this involves adding an attribute to GenFeature,
generating the rest, and hooking hasEDefault to return false if this new
attribute is set to false...
Guillaume wrote:
> Hi Ed,
> generate the whole product. But it can be explained in an accompaning
> document.
> big so far), but I do agree.
> our example (which is quite unsatisfying, and about to be changed
> accordingly to your comments).
> Guillaume
> no-longer-designed classes (making it hard to sort out generated
> classes from no-longer ones). For id issues, I'll try to suppress the
> ID tag on id attribute, and see what happens.
> Ed Merks wrote:
>> Guillaume,
>> Comments below.
>> Guillaume wrote:
>>> Ed,
>>> model using EMF. So we decided to be independent from generated
>>> code, separating hand-coded source folder from generated one.
>> all our models and of course many other people use it as well, so any
>>> element id when using provided xml persistence (with several files
>>> on disk). So we introduced a ModelElementWithId top class in our
>>> model (all others extending the latter), which provides EMF with an
>>> "ID" tagged attribute (named id :)).
>> uses them extensively and hit's used extensively in IBM's products...
>>> * Constructor.
>>> code :
>>> * @see #getId()
>>> * @generated
>>> * @ordered
>>> * @see #getId()
>>> * @generated
>>> * @ordered
>>> * @generated
>>> super();
>> constructor is a good design approach. It would seem better to
>> generate the ID on demand by overriding getID to return one rather
>> than null.
>>> new bug, that is so weird that we decide to get rid of AspectJ (for
>>> unique id for any model element, and be independent of generated
>> certainly done by many many clients.
>>> my original question.
>> be explicitly turned off on a feature by feature basis. If you open
>> a feature request, we'll consider that. The reason I thought you'd
>> give for wanting this I had thought would be related to
>> a performance impact to initialize to null rather than just leaving
>> the field in the Java default state. But you current ID
>> initialization approach has a much worse performance impact, so you
>>> Guillaume.
>>> Ed Merks wrote:
>>>> Guillaume,
>>>> Guillaume wrote:
>>>>> Hi,
>>>>> attribute ?
>>>>> attribute.
>>>>> * @see #getId()
>>>>> * @generated
>>>>> * @ordered
>>>>> * @see #getId()
>>>>> * @generated
>>>>> * @ordered
>>>>> huge difference when using a custom root class for generated java
>>>>> class, especially when trying to fill-up attributes in root class
>>>>> Thanks in advance,
>>>>> Guillaume.
Re: Attribute default value [message #407234 is a reply to message #407225] Mon, 19 February 2007 10:57 Go to previous messageGo to next message
Ed,
comments below.
Ed Merks wrote:
> Guillaume,
Well that's something we could argue about.
We have chosen the over approach (automated generation) (see martin fowler
point of view in continuous integration).
Moreover, part of the product is used as a generic framework, and requires
users to get involved in the modeling process.
So what should I do ?
Isn't the existing bug report enough ?
> Guillaume wrote:
>> Hi Ed,
>> document.
>> Guillaume
>> Ed Merks wrote:
>>> Guillaume,
>>> Comments below.
>>> Guillaume wrote:
>>>> Ed,
>>>> * Constructor.
>>>> code :
>>>> * @see #getId()
>>>> * @generated
>>>> * @ordered
>>>> * @see #getId()
>>>> * @generated
>>>> * @ordered
>>>> * @generated
>>>> super();
>>> than null.
>>>> Guillaume.
>>>> Ed Merks wrote:
>>>>> Guillaume,
>>>>> Guillaume wrote:
>>>>>> Hi,
>>>>>> attribute ?
>>>>>> attribute.
>>>>>> * @see #getId()
>>>>>> * @generated
>>>>>> * @ordered
>>>>>> * @see #getId()
>>>>>> * @generated
>>>>>> * @ordered
>>>>>> Thanks in advance,
>>>>>> Guillaume.
Re: Attribute default value [message #407235 is a reply to message #407234] Mon, 19 February 2007 11:33 Go to previous messageGo to next message
--------------050806020006090503070506
Guillaume,
The existing bug report will just change the templates to not generate
explicit assignments to a Java default value, e.g.,
protected EObject x = null;
will instead generate:
protected EObject x;
But that won't affect things that are generated as
protected String x = EDEFAULT_X;
So if you open a new bugzilla feature request, we'll look at providing
such support for this case. (Perhaps as a model level setting that says,
don't generate EDEFAULTs for features that don't have an explicit
default or as a per-feature setting.)
Guillaume wrote:
> Ed,
> comments below.
> Ed Merks wrote:
>> Guillaume,
>> run a tool to generate the things needed to make it complete. We
>> certainly commit all our code to CVS and I'm pretty sure most clients
>> take that approach. I don't see how committing the code makes it
>> harder for anyone to generate a whole product; in fact, as I said, I
>> think it makes it easier by not forcing other users to generate the
>> whole product.
> fowler point of view in continuous integration).
> requires users to get involved in the modeling process.
>> hour because mostly this involves adding an attribute to GenFeature,
>> new attribute is set to false...
>> Guillaume wrote:
>>> Hi Ed,
>>> this solution, for it forces us to have generated classes in version
>>> of control, and it makes it a bit harder for an external coder to
>>> really big so far), but I do agree.
>>> with our example (which is quite unsatisfying, and about to be
>>> changed accordingly to your comments).
>>> Guillaume
>>> the ID tag on id attribute, and see what happens.
>>> Ed Merks wrote:
>>>> Guillaume,
>>>> Comments below.
>>>> Guillaume wrote:
>>>>> Ed,
>>>> any serious problems I would want to know about and fix.
>>>>> an "ID" tagged attribute (named id :)).
>>>>> is providing with abstract method : public void setId(String ..)
>>>>> : protected String generateId().
>>>>> * Constructor.
>>>>> code :
>>>>> attribute.
>>>>> * @see #getId()
>>>>> * @generated
>>>>> * @ordered
>>>>> * @see #getId()
>>>>> * @generated
>>>>> * @ordered
>>>>> * @generated
>>>>> super();
>>>> than null.
>>>>> (for testing purposes). And now we are unable to provide a
>>>>> generated unique id for any model element, and be independent of
>>>> to guard the generation of the EDefaults, so perhaps we could add
>>>> a persistent setting to GenFeature so that the value of hasEDefault
>>>> can be explicitly turned off on a feature by feature basis. If you
>>>> open a feature request, we'll consider that. The reason I thought
>>>> you'd give for wanting this I had thought would be related to
>>>> has a performance impact to initialize to null rather than just
>>>> leaving the field in the Java default state. But you current ID
>>>>> Guillaume.
>>>>> Ed Merks wrote:
>>>>>> Guillaume,
>>>>>> the constructor can change the initial value, why does it make a
>>>>>> huge difference to not have these "default" defaults?
>>>>>> Guillaume wrote:
>>>>>>> Hi,
>>>>>>> attribute ?
>>>>>>> attribute.
>>>>>>> * @see #getId()
>>>>>>> * @generated
>>>>>>> * @ordered
>>>>>>> attribute.
>>>>>>> * @see #getId()
>>>>>>> * @generated
>>>>>>> * @ordered
>>>>>>> java class, especially when trying to fill-up attributes in root
>>>>>>> class constructor (using polymorphism on generated operations).
>>>>>>> Thanks in advance,
>>>>>>> Guillaume.
<html>
<head>
http-equiv="Content-Type">
</head>
Guillaume,<br>
<br>
explicit assignments to a Java default value, e.g.,<br>
<blockquote>protected EObject x = null;<br>
</blockquote>
will instead generate:<br>
<blockquote>protected EObject x;<br>
</blockquote>
But that won't affect things that are generated as <br>
<blockquote>protected String x = EDEFAULT_X;<br>
</blockquote>
says, don't generate EDEFAULTs for features that don't have an explicit
default or as a per-feature setting.)<br>
Re: Attribute default value [message #407242 is a reply to message #407235] Tue, 20 February 2007 02:07 Go to previous message
Hi Ed,
Ok, I'll do this.
And thanks again for your answers.
Guillaume.
Ed Merks wrote:
> Guillaume,
> Guillaume wrote:
>> Ed,
>> comments below.
>> Ed Merks wrote:
>>> Guillaume,
>>> whole product.
>>> Guillaume wrote:
>>>> Hi Ed,
>>>> Guillaume
>>>> Ed Merks wrote:
>>>>> Guillaume,
>>>>> Comments below.
>>>>> Guillaume wrote:
>>>>>> Ed,
>>>>>> * Constructor.
>>>>>> code :
>>>>>> attribute.
>>>>>> * @see #getId()
>>>>>> * @generated
>>>>>> * @ordered
>>>>>> * @see #getId()
>>>>>> * @generated
>>>>>> * @ordered
>>>>>> * @generated
>>>>>> super();
>>>>> than null.
>>>>>> Guillaume.
>>>>>> Ed Merks wrote:
>>>>>>> Guillaume,
>>>>>>> Guillaume wrote:
>>>>>>>> Hi,
>>>>>>>> attribute ?
>>>>>>>> attribute.
>>>>>>>> * @see #getId()
>>>>>>>> * @generated
>>>>>>>> * @ordered
>>>>>>>> attribute.
>>>>>>>> * @see #getId()
>>>>>>>> * @generated
>>>>>>>> * @ordered
>>>>>>>> Thanks in advance,
>>>>>>>> Guillaume.
Previous Topic:refer to model classes from a jar file
Next Topic:EMF 2.3.0M5 unsettable property
Current Time: Sat May 25 03:01:45 EDT 2013
Powered by FUDForum. Page generated in 0.01990 seconds
