Home » Modeling » EMF » XSDEditPlugin
XSDEditPlugin [message #398033] Tue, 24 January 2006 13:26 Go to next message
frank chen is currently offline frank chen
Member
XSDEditPlugin in the standalone version is still extending Plugin which is part of the eclipse core. I cannot call getPropertyDescriptors() under any of the XSD_TYPE_DefinitionItemProviders without including the core libs since they all use the XSDEditPlugin.getString method. Is this intentional or is it a bug.
Re: XSDEditPlugin [message #398034 is a reply to message #398033] Tue, 24 January 2006 13:37 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
Frank,
No, it's not intentional. If you open a bugzilla feature request, we'll
look at changing it to use the same generated pattern that is used by
other *.edit plugins.
Re: XSDEditPlugin [message #398035 is a reply to message #398033] Tue, 24 January 2006 15:03 Go to previous messageGo to next message
Member
Is there some way around it? I'm trying to create a xsd editor outside of eclipse using swing. I have a set of XSDConcreteComponent object that I'm trying to display in a tree and their properties in a table. I'm currently using the following code
XSDItemProviderAdapterFactory m_ipaf = new XSDItemProviderAdapterFactory();
ItemProviderAdapter ipa = (ItemProviderAdapter)m_ipaf.createAdapter(xsd);
List list = ipa.getPropertyDescriptors(xsd);'
and then getting each ItemPropertyDescriptor and calling getDisplayName and getPropertyValue.
That's when I run into the Exception i mentioned at the line ipa.getPropertyDescriptors
Re: XSDEditPlugin [message #398036 is a reply to message #398035] Tue, 24 January 2006 15:07 Go to previous messageGo to next message
Frank,
The only workaround is to run as a headless Eclipse application.
Hopefully the proper change will be simple and it's something we could
do in a few hours...
Re: XSDEditPlugin [message #398037 is a reply to message #398034] Tue, 24 January 2006 15:19 Go to previous messageGo to next message
Member
Re: XSDEditPlugin [message #398038 is a reply to message #398037] Tue, 24 January 2006 15:26 Go to previous messageGo to next message
Frank,
You're repeating yourself, so I will to: The only workaround is to run
as a headless Eclipse application. Hopefully the proper change will be
simple and it's something we could do in a few hours...
Re: XSDEditPlugin [message #398039 is a reply to message #398038] Tue, 24 January 2006 15:59 Go to previous messageGo to next message
Member
What I'm working on really depends on it. It would be great if it can be fixed soon. When do think the bug will be fixed?
Re: XSDEditPlugin [message #398040 is a reply to message #398039] Tue, 24 January 2006 16:07 Go to previous messageGo to next message
Frank,
If all goes well, I might be able to do it tomorrow and then it would be
in Thursday's build. Please open the bugzilla enhancement request for it.
Re: XSDEditPlugin [message #398041 is a reply to message #398039] Tue, 24 January 2006 16:52 Go to previous messageGo to next message
Frank,
The changes are easy. I have them ready to commit, pending your
bugzilla to commit them against...
Re: XSDEditPlugin [message #398042 is a reply to message #398041] Tue, 24 January 2006 18:41 Go to previous message
Member
I have added the bug to bugzilla. The id is 125096. Thanks for your timely response.
Previous Topic:How to connect my ecore model with my another ecore model?
Next Topic:Opposite references in Maps?
Current Time: Thu May 23 19:38:12 EDT 2013
Powered by FUDForum. Page generated in 0.01927 seconds
