since i have installed the new bot version 2.0.0.329, a simple button
click doesn't funktion any more :-( (e.g. bot.button("bla").click()).
I have reset to the older version (.187), and it functions ok as before ...
Is it a bug, or i made something wrong by update?
java.lang.NoSuchMethodError:
org.eclipse.swtbot.swt.finder.widgets.SWTBotButton.click()Lo rg/eclipse/swtbot/swt/finder/widgets/SWTBotButton;
de.cenit.eb.sm.finca.gui.test.serverconfperspective.TestsFor PluginConfigurationView.testInitButtonsAndMenues(Unknown
Source)
org.eclipse.swtbot.swt.finder.SWTBotTestCase.runBare(SWTBotT estCase.java:228)
org.eclipse.swtbot.eclipse.junit4.headless.EclipseTestRunner .run(EclipseTestRunner.java:350)
org.eclipse.swtbot.eclipse.junit4.headless.EclipseTestRunner .run(EclipseTestRunner.java:208)
org.eclipse.swtbot.eclipse.junit4.headless.UITestApplication .runTests(UITestApplication.java:190)
org.eclipse.ui.internal.testing.WorkbenchTestable$1.run(Work benchTestable.java:68)
at java.lang.Thread.run(Unknown Source)
On 29/5/09 20:05, Pavel Cybulskij wrote:
> Hello,
> This is the exception of .329:
> at
> Source)
> at
> at
> at
> at
> at
it's me again with my Problem in SWTBotButton.click().
I'm starting swtbot always via ant script. I have already updated to
version .340 (inclusive "Headless Testing Framework"), but the problem
remains the same! :-(
Funnily enough the fact, that ONLY the method button("bla").click()
doesn't function in versions .329 and .340 (it throws still Exception
'NoSuchMethodError'). The other methods of button (e.g. .getText() or
setFocus() function well in new versions!) In v.187 ALL functions are OK!
HELP please!!! :-)
Do you have any documentation for swtbot? i didn't found it on your site
There may be no binary compatibility between those two versions, are you
running the same binaries of your source against different versions of
swtbot without recompiling them ?
If your source builds fine then it should execute fine unless the
binaries being used are different.
On 8/6/09 19:47, Pavel Cybulskij wrote:
> Hello Ketan,
> remains the same! :-( Funnily enough the fact, that ONLY the method
> button("bla").click() doesn't function in versions .329 and .340 (it
> throws still Exception 'NoSuchMethodError'). The other methods of button
> (e.g. .getText() or setFocus() function well in new versions!) In v.187
> HELP please!!! :-)
> Bye,
> Pavel
Finally i have solved this problem! All i needed was 'clear' by ant
relaunch. :-)
> relaunch. :-)
>> you running the same binaries of your source against different
>> versions of swtbot without recompiling them ?
