Home » Eclipse Projects » EclipseLink » Transactions
Transactions [message #387785] Wed, 13 May 2009 06:57 Go to next message
Yolanda is currently offline Yolanda
Hello
I have a problem with transactions.
I need to invoke a method of a SessionBean within a preUpdate event of an
Entity.
public void preUpdate(DescriptorEvent event) {
Object orrFacade = new InitialContext().lookup("OrrFacadeEJB");
BigDecimal data = ((OrrFacade)orrFacade).getDataFromDB();
But if I do it I obtain this exception:
"javax.transaction.SystemException: Only one single phase commit resource
may be enlisted in a transaction"
How could I do it?
Thanks for your help:
Yolanda.
Re: Transactions [message #387790 is a reply to message #387785] Wed, 13 May 2009 10:16 Go to previous messageGo to next message
James Sutherland is currently offline James Sutherland
Does the SessionBean access another database? It looks like your JTA
driver cannot create an XA transaction across these two data-sources.
Maybe change the transaction attribute of the SessionBean method to avoid
a transaction, or start a new transaction (not_supports or requires_new I
think).
If it is the same DataSource, then that is odd. Ensure the SessionBean is
a local SessionBean.
James
http://www.nabble.com/EclipseLink---Users-f26658.html
James : Wiki : Book : Blog
Re: Transactions [message #387925 is a reply to message #387790] Fri, 15 May 2009 09:31 Go to previous messageGo to next message
Hello James, thanks for your replay.
When I do a lookup in the preUpdate method of a entity, I get a Remote
sessionBean, I can't understand why this is happening,
and I don't know how I can fix it.
Any idea?
Re: Transactions [message #387939 is a reply to message #387925] Tue, 19 May 2009 13:52 Go to previous messageGo to next message
You can make a SessionBean local by using @Local instead of @Remote in the
SessionBean class.
Re: Transactions [message #389705 is a reply to message #387939] Mon, 22 June 2009 07:06 Go to previous message
Hi James.
I initialized wrong the InitialContext.
Previous Topic:fetch multi-level relations
Next Topic:toplink console, JMX
Current Time: Thu May 23 19:31:48 EDT 2013
Powered by FUDForum. Page generated in 0.01936 seconds
