Home » Eclipse Projects » EclipseLink » Eclipselink with Java Web Start
Eclipselink with Java Web Start [message #389402] Wed, 03 June 2009 17:43 Go to next message
pro3x is currently offline pro3x
I've created application that uses Eclipselink for persistence and Java
Web Start for installation and updates. Application works "normally" when
I'm online, but when I'm offline and I start the application from Java
Cache Viewer with "Run Offline" it breaks with following exception.
When online, application hangs for few minutes on
javax.persistence.Persistence.createEntityManagerFactory("").createEntityManager()
while downloading something, than continues normally.
Application: http://www.pro3x.com/jws/launch.jnlp
Source code: http://www.pro3x.com/jws/src.zip
Please help. Thank you.
Local Exception Stack:
Exception [EclipseLink-30005] (Eclipse Persistence Services -
1.1.1.v20090430-r4097):
org.eclipse.persistence.exceptions.PersistenceUnitLoadingExc eption
Exception Description: An exception was thrown while searching for
persistence archives with ClassLoader: com.sun.jnlp.JNLPClassLoader@6f7ce9
Internal Exception: Exception [EclipseLink-30004] (Eclipse Persistence
Services - 1.1.1.v20090430-r4097):
Exception Description: An exception was thrown while processing
persistence.xml from URL: http://www.pro3x.com/jws/pro3.jar
Internal Exception: java.net.MalformedURLException
org.eclipse.persistence.exceptions.PersistenceUnitLoadingExc eption.exceptionSearchingForPersistenceResources(Persistence UnitLoadingException.java:121)
org.eclipse.persistence.jpa.PersistenceProvider.createEntity ManagerFactory(PersistenceProvider.java:133)
org.eclipse.persistence.jpa.PersistenceProvider.createEntity ManagerFactory(PersistenceProvider.java:67)
javax.persistence.Persistence.createEntityManagerFactory(Per sistence.java:123)
javax.persistence.Persistence.createEntityManagerFactory(Per sistence.java:99)
at Acosoft.Processing.PregledRacuna.initComponents(PregledRacun a.java:64)
at Acosoft.Processing.PregledRacuna.<init>(PregledRacuna.java:45)
at Acosoft.Processing.Pro3View.OtvoriStorniranjeRacuna(Pro3View .java:673)
at Acosoft.Processing.Pro3View.access$2400(Pro3View.java:41)
at Acosoft.Processing.Pro3View$19.actionPerformed(Pro3View.java :483)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.AbstractButton.doClick(Unknown Source)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased (Unknown
Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Caused by: Exception [EclipseLink-30004] (Eclipse Persistence Services -
org.eclipse.persistence.exceptions.PersistenceUnitLoadingExc eption.exceptionProcessingPersistenceXML(PersistenceUnitLoad ingException.java:112)
org.eclipse.persistence.internal.jpa.deployment.PersistenceU nitProcessor.processPersistenceXML(PersistenceUnitProcessor. java:357)
org.eclipse.persistence.internal.jpa.deployment.PersistenceU nitProcessor.processPersistenceArchive(PersistenceUnitProces sor.java:314)
org.eclipse.persistence.internal.jpa.deployment.PersistenceU nitProcessor.getPersistenceUnits(PersistenceUnitProcessor.ja va:237)
org.eclipse.persistence.internal.jpa.deployment.JPAInitializ er.initPersistenceUnits(JPAInitializer.java:155)
org.eclipse.persistence.internal.jpa.deployment.JPAInitializ er.initialize(JPAInitializer.java:144)
org.eclipse.persistence.jpa.PersistenceProvider.createEntity ManagerFactory(PersistenceProvider.java:105)
... 35 more
Caused by: java.net.MalformedURLException
at java.net.URL.<init>(Unknown Source)
com.sun.org.apache.xerces.internal.impl.XMLEntityManager.set upCurrentEntity(Unknown
Source)
com.sun.org.apache.xerces.internal.impl.XMLVersionDetector.d etermineDocVersion(Unknown
Source)
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown
Source)
Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown
Source)
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown
Source)
com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse(Unknown
Source)
org.eclipse.persistence.internal.jpa.deployment.PersistenceU nitProcessor.processPersistenceXML(PersistenceUnitProcessor. java:355)
... 40 more
Re: Eclipselink with Java Web Start [message #389425 is a reply to message #389402] Tue, 09 June 2009 10:25 Go to previous messageGo to next message
James Sutherland is currently offline James Sutherland
It seems to be trying to access the schema from the url you gave in you
persistence.xml.
Can you try changing your persistence.xml header to,
<persistence xmlns="http://java.sun.com/xml/ns/persistence"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://java.sun.com/xml/ns/persistence
persistence_1_0.xsd" version="1.0">
Does this work?
James
http://www.nabble.com/EclipseLink---Users-f26658.html
James : Wiki : Book : Blog
Re: Eclipselink with Java Web Start [message #389459 is a reply to message #389425] Thu, 11 June 2009 12:24 Go to previous message
Hello. Thank you for your reply.
I have located cause of my problems. The function in URLArchive class (see
below) causes redownload of jar file that contains persistence.xml file.
public InputStream getEntry(String entryPath) throws IOException
URL subEntry = new URL(url, entryPath);
InputStream is = null; stari kod
try {
is = subEntry.openStream();
} catch (IOException ioe) {
// we return null when entry does not exist
return is;
Since I have only one persistence.xml file I replaced function with
InputStream is = Thread.currentThread()
.getContextClassLoader().getResourceAsStream(entryPath);
return is;
I've changed AchiveFactoryImpl function to use only URLArchive class.
public Archive createArchive(URL url) throws URISyntaxException,
IOException {
logger.entering("ArchiveFactoryImpl", "createArchive", new
Object[]{url});
Archive result = null;
String protocol = url.getProtocol();
logger.logp(Level.FINER, "ArchiveFactoryImpl", "createArchive",
"protocol = {0}", protocol);
// if ("file".equals(protocol)) {
// URI uri = Helper.toURI(url);
// File f;
// try {
// // Attempt to create the file with the uri. The
pre-conditions
// // are checked in the constructor and an exception is
thrown
// // if the uri does not meet them.
// f = new File(uri);
// } catch (IllegalArgumentException e) {
// // Invalid uri for File. Go our back up route of using
the
// // path from the url.
// f = new File(url.getPath());
// if (f.isDirectory()) {
// // e.g. file:/tmp/a_ear/ejb_jar
// result = new DirectoryArchive(f);
// } else {
// // e.g. file:/tmp/a_ear/lib/pu.jar
// // It's not a directory. Then it must be a jar file.
// result = new JarFileArchive(new JarFile(f));
// } else if ("jar".equals(protocol)) { // NOI18N
// JarURLConnection conn =
JarURLConnection.class.cast(url.openConnection());
// JarEntry je = conn.getJarEntry();
// if (je == null) {
// // e.g. jar:file:/tmp/a_ear/lib/pu.jar!/
// // No entryName specified, hence URL points to a JAR
file and
// // not to any entry inside it. Ideally this should have
been
// // file:/tmp/a_ear/lib/pu.jar,
// // but containers (e.g.) WebLogic return this kind of
URL,
// // so we better handle this in our code to imrove
pluggability.
// // Read the entire jar file.
// result = new JarFileArchive(conn.getJarFile());
// } else if (je.isDirectory()) {
// // e.g. jar:file:/tmp/a_ear/b.war!/WEB-INF/classes/
// // entryName [je.getName()] is a directory
// result = new DirectoryInsideJarURLArchive(url);
// } else {
// // some URL (e.g.)
jar:file:/tmp/a_ear/b.war!/WEB-INF/lib/pu.jar
// // entryName [je.getName()] is a file, so treat this URL
as a
// // URL from which a JAR format InputStream can be
obtained.
// result = new JarInputStreamURLArchive(url);
// } else if (isJarInputStream(url) || false){
// } else {
// result = new URLArchive(url);
logger.exiting("ArchiveFactoryImpl", "createArchive", result);
return result;
This is just a dirty hack until this is solved. I'dont use Eclipse and
Maven, so I used bundled sources with dependent jar files and compiled it
with Netbeans.
The problem can only be traced in "http://" deployment, because in
"file://" deployment it works fast because it reads local file system.
Should I report this as a bug? I think that the problem is only in Java
1.6 version because of the changes to getResources (I found some post on
the forums that talked about this). I didn't test my application with Java
1.5 so I can't confirm this.
Thank you. Bye.
Previous Topic:Setting entity's cache type to none throws StackOverflowError
Next Topic:Is there a way to automatically expire entity from cache when using EM's find()?
Current Time: Fri May 24 09:44:31 EDT 2013
Powered by FUDForum. Page generated in 0.01612 seconds
