Home » Eclipse Projects » EclipseLink » weaving or not
weaving or not [message #386017] Thu, 19 March 2009 09:07 Go to next message
Tom Eugelink is currently offline Tom Eugelink
In the EclipseLink initialization code I need to set whether we are weaving or not:
cfg.put(PersistenceUnitProperties.WEAVING, "true");
However, this in fact is determined at runtime, by:
- the fact that the BM jar in the classpath is preweaved
- the fact that the -javaagent:eclipselink1.0.2.jar option is present
If I were to change my runtime configuration and remove the javaagent option and add the preweaved jar, that should be enough to allow a correct start. However, now I still need to make a compile-time change to the configuration to set weaving to false.
Is it possible to detect at runtime if the agent is weaving so the option can be set correctly?
Tom
Re: weaving or not [message #386055 is a reply to message #386017] Mon, 23 March 2009 09:34 Go to previous messageGo to next message
James Sutherland is currently offline James Sutherland
You should be able to always set weaving to true, as I think the inverse
will work even if weaving did not occur, then weaved features will not be
enabled.
I think there are some features that currently auto-detect weaving, and
others that require the weaving option be set. You could log a bug to
have everything be able to auto-detect, in theory it seems that it would
be possible.
James
http://www.nabble.com/EclipseLink---Users-f26658.html
James : Wiki : Book : Blog
Re: weaving or not [message #386061 is a reply to message #386055] Mon, 23 March 2009 10:14 Go to previous message
> be enabled.
I stepwise tried to make the preweaved jar work, but I needed to set that option to false. Maybe 1.1 will behave better, I but have an exception there ATM (reported in another thread).
[RT] Bug#: 269688
Previous Topic:@Transformation - Unknown state or association field
Next Topic:mapping problem: entity as join table
Current Time: Tue May 21 16:25:31 EDT 2013
Powered by FUDForum. Page generated in 0.01829 seconds
