| OneToMany associations [message #385412] |
Thu, 29 January 2009 19:59  |
David J Rericha Messages: 13 Registered: July 2009 |
Junior Member |
Dear members,
I am experimenting with OneToMany associations in the following senario:
Patient with addresses in a bi-directional one-to-many association (These
are rich patients). I also set cascade=ALL with @PrivateOwned.
I encountered the following:
1) In order to create a patient and add addresses, I must set the patient
in each address and then persist the patient. I cannot just add the
addresses to patient.addresses and save the patient (in this case the
patient and the addresses are saved, but the foreign key is not set in the
addresses). Is this the intended behavior?
2) I am not sure what @PrivateOwned accomplishes. I get the same behavior
with just cascade=ALL when persisting and removing the patient.
@Entity
@Table(name="test_patient")
public class Patient extends Model
@OneToMany(mappedBy = "patient", cascade = ALL )
@PrivateOwned
private List<Address> addresses = new ArrayList<Address>();...
@Entity
public class Address extends Model
@ManyToOne( fetch=LAZY)
@JoinColumn(name="pat_id", referencedColumnName = "ID")
private Patient patient;...
David
| Re: OneToMany associations [message #385413 is a reply to message #385412] |
Thu, 29 January 2009 23:35  |
Doug Clarke Messages: 155 Registered: July 2009 |
David,
Yes, It is up to you to maintain the relationships in the domain model.
This is required of you so that the domain model functions the same when
it is not managed by an entity manager. This is typically done in the
addAddress method:
public void addAddress(Address address) {
this.addresses.add(address);
address.setPatient(this);
Yes, cascade-delete will cause the addresses to be deleted when the
Patient is explicitly removed in a transaction. The @PrivateOwned offers
the additional benefit of deleting any address that is removed from the
collection without requiring it to be removed directly.
Doug
FUDForum. Page generated in 0.01463 seconds
