| [Epsilon] top-level container in EOL [message #385354] |
Fri, 05 September 2008 23:23  |
Kimon Polychroniadis Messages: 30 Registered: July 2009 |
Member |
I was wondering whether there is a built-in operation to find the
top-lever container of a model element.
E.g.
A contains B contains C contains D
is there a method that allows me to find the top-level container, which
in that case would be container A?
Thank you in advance,
Kimon
| Re: [Epsilon] top-level container in EOL [message #385355 is a reply to message #385354] |
Sat, 06 September 2008 04:17  |
Dimitrios Kolovos Messages: 1772 Registered: July 2009 |
Hi Kimon,
There is no such built-in operation. However, the following operation
should do the job:
operation Any topEContainer() {
if (self.eContainer().isDefined()) {
return self.eContainer().topEContainer();
else {
return self;
Dimitris
Kimon Polychroniadis wrote:
> Hello,
> E.g.
> Kimon
| Re: [Epsilon] top-level container in EOL [message #621765 is a reply to message #385354] |
Hi Kimon,
should do the job:
else {
return self;
Dimitris
> Hello,
> E.g.
> Kimon
FUDForum. Page generated in 0.02017 seconds
