| [Epsilon]EWL Wizards problem [message #385303] |
Sat, 30 August 2008 14:09  |
Kimon Polychroniadis Messages: 30 Registered: July 2009 |
Member |
I have an EWL file, containing a couple of wizards. Just a couple of
weeks ago, the wizard would work just fine with the diagram I generated
(using EuGENia). However, when I try to use the same wizards the
"Wizards" menu is now empty. I have done step-by-step the instructions
on EWL's screencast, yet I still have that problem.
The same problem goes for any kind of wizard, even the simplest ones.
Any ideas on how I should deal with this?
Thank you in advance,
Kimon
| Re: [Epsilon]EWL Wizards problem [message #385306 is a reply to message #385303] |
Sat, 30 August 2008 14:21   |
Dimitrios Kolovos Messages: 1772 Registered: July 2009 |
Hi Kimon,
You should re-configure your wizards from Preferences->Epsilon... In the
latest version, instead of the file extension you should specify the
namespace URI. I will update the screencast and the related docs shortly.
Dimitris
> Kimon
| Re: [Epsilon]EWL Wizards problem [message #385308 is a reply to message #385306] |
Sat, 30 August 2008 16:57  |
Member |
Thank you for your help! Indeed, all I had to do is replace the the file
extension with the metamodel's namespace URI.
Kimon
O/H Dimitrios Kolovos έγραψε:
> Hi Kimon,
> Cheers,
> Dimitris
>> generated (using EuGENia). However, when I try to use the same wizards
>> the "Wizards" menu is now empty. I have done step-by-step the
>> instructions on EWL's screencast, yet I still have that problem.
>> Kimon
| Re: [Epsilon]EWL Wizards problem [message #621693 is a reply to message #385303] |
Hi Kimon,
Dimitris
> Kimon
| Re: [Epsilon]EWL Wizards problem [message #621695 is a reply to message #385306] |
Member |
Kimon
> Hi Kimon,
> Cheers,
> Dimitris
>> Kimon
FUDForum. Page generated in 0.01700 seconds
