Home » Modeling » GMT (Generative Modeling Technologies) » [Eugenie].emf file association gone weird
[Eugenie].emf file association gone weird [message #385205] Wed, 27 August 2008 15:53 Go to next message
Eclipse User
Originally posted by: johannes.nel.gmail.com
hi
i installed the epsilon plugin from the update site, downloaded the
Eugenia source from svn and created plugin projects for both the eugenie
and runtime projects.
however when i start my secondary eclipse the emf file extension is
owned by some app on my win box, and i do not have the eugenie menu
associated with it.
Can I change the associated fiel extension easily?
johan
Re: [Epsilon].emf file association gone weird [message #385285 is a reply to message #385205] Sat, 30 August 2008 03:39 Go to previous message
Dimitrios Kolovos is currently offline Dimitrios Kolovos
Hi Johan,
Could you please remember to prefix future posts using [Epsilon] as
dictated by the newsgroup policy (http://wiki.eclipse.org/index.php/GMT).
Re your question do you mean that in your 1st workbench you *can* open
and edit .emf files using the Emfatic editor (syntax highlighting etc..)
while in the 2nd you cannot? If that is the case perhaps you should
check the selected plugins in your Eclipse Application launch
configuration (Plug-ins tab). If not please make sure that you have
Emfatic (http://www.alphaworks.ibm.com/tech/emfatic) installed.
As discussed in http://epsilonlabs.wiki.sourceforge.net/EuGENia, the new
version of Emfatic doesn't seem to support detail-less annotations (e.g.
@gmf.diagram) so the old version from the IBM Alphaworks website should
be used instead - at least until this is fixed.
Dimitrios
johannes wrote:
> hi
> associated with it.
> johan
Re: [Epsilon].emf file association gone weird [message #621682 is a reply to message #385205] Sat, 30 August 2008 03:39 Go to previous message
Hi Johan,
Dimitrios
johannes wrote:
> hi
> associated with it.
> johan
Previous Topic:[MOFScript]i+=1 acturally add by two
Next Topic:[Epsilon][Eugenia]Multiple compartments problem
Current Time: Thu May 23 11:31:44 EDT 2013
Powered by FUDForum. Page generated in 0.01627 seconds
