| [MOFScript]transformation code [message #384875] |
Fri, 22 August 2008 04:10  |
yeliu Messages: 145 Registered: July 2009 |
I have a series instances of different class.the relations of them looks
like the following:
a
b
b1 b2 b3
c1 c2 c3
d1 d2 d3
d
e
b contains 3 outports:b1,b2,b3.
d contains 3 inports:d1,d2,d3.
The target code that I want to generate looks like this:
connect a->b
connect b1->c1->d1
connect b2->c2->d2
connect b3->c3->d3
connect d->e
Hope I describe clearly!
How do I write this code in MORScript?
Thank you very much!
Ye
| Re: [MOFScript]transformation code [message #385273 is a reply to message #384875] |
Thu, 28 August 2008 08:58  |
Tor Neple Messages: 57 Registered: July 2009 |
Member |
Hello
I wrote this answer after answering your newer post.
I guess approach to take will vary depending on what you want to
acheive, or what the rules for the output are. Do you want to calculate
all paths from a to d? Or is the rule more like:
if node only has one outconnection
print that connection
etc
What I am trying to get at is how are the rules formulated that say that
the next line to print is not b->b1 then b->b2 and b->b3?
As mentioned in the earlier post this case smells a bit of recursion (or
nested forEach loops)
Tor
Ye Liu wrote:
> Hello,
> like the following:
> a
> b
> b1 b2 b3
> c1 c2 c3
> d1 d2 d3
> d
> e
> connect a->b
> connect b1->c1->d1
> connect b2->c2->d2
> connect b3->c3->d3
> connect d->e
> How do I write this code in MORScript? Thank you very much!
> Ye
| Re: [MOFScript]transformation code [message #620464 is a reply to message #384875] |
Member |
Hello
etc
Tor
Ye Liu wrote:
> Hello,
> like the following:
> a
> b
> b1 b2 b3
> c1 c2 c3
> d1 d2 d3
> d
> e
> connect a->b
> connect b1->c1->d1
> connect b2->c2->d2
> connect b3->c3->d3
> connect d->e
> Ye
FUDForum. Page generated in 0.03697 seconds
