| Converting from Hibernate composite-element mapping [message #385169] |
Mon, 29 December 2008 14:54  |
David J Rericha Messages: 13 Registered: July 2009 |
Junior Member |
Dear members,
I cannot seem to figure out how to convert composite-element mappings from
Hibernate to JPA (I am using xml rather than annotations). The senario
should not be too uncommon: I have patient entities in a many-to-many
association with diagnosis (Icdm) entities. However, the join table,
patient_icdm, needs to have additional qualifying fields, i.e. sequence,
date of diagnosis, etc. The only way I have seen to do this in JPA is to
map the PersonIcdm object as an entity. The current table created with
the composite-element mapping does not have a primary key ( Hibernate
creates a run-time composite-primary-key for deletes comprised of all the
fields of the composite-element ). In order to do this in JPA, the
elements of the primary-key class have to be primitives or
primitive-wrappers, or Dates. But this join-object is joining entities:
Person and Diagnosis. How do I go about this? Here are my objects and
mappings:
public class Patient implements Serializable
private long id;
private String firstName;
private String lastName;
private Address address;
private List<PatientIcdm> PatientIcdms = new ArrayList<PatientIcdm>();
private static final long serialVersionUID = 1L;
public Patient()
super();
public long getId()
return this.id;
public void setId( long id )
this.id = id;
public String getFirstName()
return this.firstName;
public void setFirstName( String firstName )
this.firstName = firstName;
public String getLastName()
return this.lastName;
public void setLastName( String lastName )
this.lastName = lastName;
public Address getAddress()
return this.address;
public void setAddress( Address address )
this.address = address;
public String toString()
return firstName + " " + lastName;
public List<PatientIcdm> getPatientIcdms()
return patientIcdms;
public void setPatientIcdms( List<PatientIcdm> patientIcdms )
this.patientIcdms = patientIcdms;
public class PatientIcdm
private int sequence;
private Patient patient;
private Icdm icdm;
public int getSequence()
return sequence;
public void setSequence( int sequence )
this.sequence = sequence;
public Patient getPatient()
return patient;
public void setPatient( Patient Patient )
this.patient = patient;
public Icdm getIcdm()
return icdm;
public void setIcdm( Icdm icdm )
this.icdm = icdm;
public class Icdm
private int icdmId;
private String name;
private String description;
public String getName()
return name;
public void setName( String name )
this.name = name;
public String getDescription()
return description;
public void setDescription( String description )
this.description = description;
public int getIcdmId()
return icdmId;
public void setIcdmId( int icdmId )
this.icdmId = icdmId;
hibernate.hbm.xml:
<bag name="patientIcdms" table="patient_icdm"
cascade="save-update,delete,evict,refresh" order-by="paticdm_seq_nbr">
<key column="paticdm_pat_id"/>
<composite-element class="com.moms.models.PatientIcdm">
<many-to-one name="icdm" column="paticdm_icdm_id"
class="com.moms.models.Icdm" cascade="save-update,evict,refresh"/>
<property name="sequence" column="paticdm_seq_nbr" type="int"/>
</composite-element>
</bag>
orm.xml:
<entity-mappings>
<entity class="quickstart.demo.model.Person" access="PROPERTY">
<table name="person">
</table>
<attributes>
<id name="id">
<column name="person_id"/>
<generated-value generator="person_seq" strategy="SEQUENCE" />
<sequence-generator name="person_seq" allocation-size="1"
initial-value="1" />
</id>
<basic name="firstName">
</basic>
<basic name="lastName">
<column column-definition="type text"/>
</basic>
<many-to-one name="address" fetch="LAZY">
<join-column name="address_id" referenced-column-name="address_id"
<cascade>
<cascade-all />
</cascade>
</many-to-one>
</attributes>
</entity>
<entity class="quickstart.demo.model.Icdm" access="PROPERTY">
<table name="icdm"></table>
<attributes>
<id name="icdmId">
<column name="icdm_id" />
<generated-value generator="icdm_seq" strategy="SEQUENCE" />
<sequence-generator name="icdm_seq" allocation-size="1"
</id>
<basic name="name" />
<basic name="description" />
</attributes>
</entity>
</entity-mappings>
FUDForum. Page generated in 0.01605 seconds
