Home » Modeling » GMT (Generative Modeling Technologies) » [xtext] Error in the generated PartitionScanner
[xtext] Error in the generated PartitionScanner [message #384445] Wed, 06 August 2008 11:24 Go to next message
Lorenzo Bettini is currently offline Lorenzo Bettini
by taking a look at the generated antlr grammar, the STRING token takes
care of escaping character \ (which is a really good thing :-)
RULE_STRING :
'"' ( '\\' ('b'|'t'|'n'|'f'|'r'|'\"'|'\''|'\\') | ~('\\'|'"') )* '"' |
'\'' ( '\\' ('b'|'t'|'n'|'f'|'r'|'\"'|'\''|'\\') | ~('\\'|'\'') )* '\''
However, the generated GeneratedPartitionScanner.java in the .editor
plugin, does not consider the escape character:
public class GeneratedPartitionScanner extends AbstractPartitionScanner {
public List<IPredicateRule> getRules() {
List<IPredicateRule> rules = new ArrayList<IPredicateRule>();
rules.add(new MultiLineRule("\"","\"", string));
rules.add(new MultiLineRule("'","'", string));
return rules;
in fact, in the generated editor the highlighting of a string of the shape
"this is \"a test\""
does not generate an error (right!) but it is not highlighted correctly.
The generated partition scanner should consider the escape character:
rules.add(new MultiLineRule("\"","\"", string, '\\'));
rules.add(new MultiLineRule("'","'", string, '\\'));
return rules;
where should I fix this?
if I modify the generated partition scanner directly I assume it will be
overwritten...
thanks
Lorenzo
Lorenzo Bettini, PhD in Computer Science, DI, Univ. Torino
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: [xtext] Error in the generated PartitionScanner [message #384650 is a reply to message #384445] Fri, 08 August 2008 02:27 Go to previous messageGo to next message
Sven Efftinge is currently offline Sven Efftinge
Hi Lorenzo,
it would be best if you could provide a patch and file it in bugzilla,
so that the issue is fixed for everybody :-)
In general if you want to configure a special partition scanner you
should subclass the generated [LanguageName]Utilities.java class in the
editor project. The subclass should of course go into the src/ folder.
Then change the [LanguageName]EditorPlugin class so that it instantiates
the new subclass instead of the generated class.
In the manually created utility class you can overwrite the method:
public IPartitionTokenScanner getPartitionScanner() {
// TODO Auto-generated method stub
return super.getPartitionScanner();
Note, that this is how you can replace other built-in functionality as
well (e.g. content assist).
hope that helps,
Sven
> RULE_STRING :
> @Override
> return rules;
> @Override
> return rules;
> overwritten...
> thanks
> Lorenzo
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
Re: [xtext] Error in the generated PartitionScanner [message #384659 is a reply to message #384650] Fri, 08 August 2008 05:29 Go to previous messageGo to next message
Sven Efftinge wrote:
> Hi Lorenzo,
I'll try to do this, but it might not be easy for someone external to
the development of xtext code itself to try to figure out where to patch ;-)
anyway, I'm trying to download the sources; I assume the right procedure
is the one described in the wiki am I right?
> @Override
OK, I managed to figure this out and already did that :-)
Note that if you override a standard rule, as for instance the single
comment rule, the generated partition scanner is not updated
accordingly... so you end up with an highlighting scheme that is not
consistent with the parser... was that intentional or is it a bug?
> hope that helps,
> Sven
>> RULE_STRING :
>> @Override
>> return rules;
>> shape
>> @Override
>> return rules;
>> overwritten...
>> thanks
>> Lorenzo
Re: [xtext] Error in the generated PartitionScanner [message #384663 is a reply to message #384650] Fri, 08 August 2008 12:47 Go to previous messageGo to next message
--------------070706060603020106050406
> Hi Lorenzo,
there seem to be problems with bugzilla, so for the moment I'm posting
the patch here
hope this helps
Lorenzo
Content-Type: text/x-diff;
name="scanner_with_escape_chars_for_strings.patch"
Content-Disposition: inline;
filename="scanner_with_escape_chars_for_strings.patch"
### Eclipse Workspace Patch 1.0
#P xtext.generator
Index: main/src/org/openarchitectureware/xtext/editor/Utilities.xpt
RCS file: /cvsroot/architecturware/oaw_v4/xtext/xtext.generator/main/s rc/org/openarchitectureware/xtext/editor/Utilities.xpt,v
retrieving revision 1.6.2.3.2.1
diff -u -r1.6.2.3.2.1 Utilities.xpt
--- main/src/org/openarchitectureware/xtext/editor/Utilities.xpt 31 May 2008 12:57:18 -0000 1.6.2.3.2.1
+++ main/src/org/openarchitectureware/xtext/editor/Utilities.xpt 8 Aug 2008 16:16:50 -0000
@@ -103,8 +103,8 @@
rules.add(new MultiLineRule("/*","*/", comment));
rules.add(new SingleLineRule("//", "", comment));
�ENDIF-�
- rules.add(new MultiLineRule("\"","\"", string));
- rules.add(new MultiLineRule("'","'", string));
+ rules.add(new MultiLineRule("\"","\"", string, '\\'));
+ rules.add(new MultiLineRule("'","'", string, '\\'));
return rules;
--------------070706060603020106050406--
Re: [xtext] Error in the generated PartitionScanner [message #384664 is a reply to message #384650] Fri, 08 August 2008 12:47 Go to previous messageGo to next message
--------------030806020307050809080108
> Hi Lorenzo,
the patch here
hope this helps
Lorenzo
#P xtext.generator
@@ -103,8 +103,8 @@
�ENDIF-�
return rules;
--------------030806020307050809080108--
Re: [xtext] Error in the generated PartitionScanner [message #384665 is a reply to message #384664] Fri, 08 August 2008 12:52 Go to previous messageGo to next message
>> Hi Lorenzo,
> the patch here
OK: https://bugs.eclipse.org/bugs/show_bug.cgi?id=243608
Re: [xtext] Error in the generated PartitionScanner [message #384779 is a reply to message #384665] Wed, 13 August 2008 11:23 Go to previous messageGo to next message
This also has already been applied by Patrick.
Thank you!
>>> Hi Lorenzo,
>>> bugzilla, so that the issue is fixed for everybody :-)
>> the patch here
Re: [xtext] Error in the generated PartitionScanner [message #384781 is a reply to message #384779] Wed, 13 August 2008 12:35 Go to previous messageGo to next message
thank you for xtext :-)
> Thank you!
>>>> Hi Lorenzo,
>>> posting the patch here
Re: [xtext] Error in the generated PartitionScanner [message #384880 is a reply to message #384781] Fri, 22 August 2008 04:22 Go to previous messageGo to next message
Scott Hendrickson is currently offline Scott Hendrickson
Member
It seems to me that the problem is that the STRING definition is
incorrect. See this thread for my explanation of why I think this:
http://www.openarchitectureware.org/forum/viewtopic.php?show topic=9640
Also, should I be posting on this newsgroup or that one?
-- Scott
Re: [xtext] Error in the generated PartitionScanner [message #384890 is a reply to message #384880] Fri, 22 August 2008 07:50 Go to previous messageGo to next message
For the currently released xtext (shipped with oAW 4.3) it's best to use
the forum over at openarchitectureware.org.
If people have questions about the new Xtext (the one currently
developed under TMF) they should aks here (eclipse.modeling.tmf).
Since there are no releases yet, there are no questions :-)
regards,
Sven
> -- Scott
Re: [xtext] Error in the generated PartitionScanner [message #384901 is a reply to message #384880] Sat, 23 August 2008 13:10 Go to previous message
As I also answered to that thread:
Actually, concerning the bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=243608, which
now should be fixed in the CVS, the strings with backslashed quotes used
to work correctly as before (the parser used to parse it correctly), it
was the highlighter that was wrong...
Re: [xtext] Error in the generated PartitionScanner [message #618902 is a reply to message #384445] Fri, 08 August 2008 02:27 Go to previous message
Hi Lorenzo,
hope that helps,
Sven
> RULE_STRING :
> @Override
> return rules;
> @Override
> return rules;
> overwritten...
> thanks
> Lorenzo
Re: [xtext] Error in the generated PartitionScanner [message #619450 is a reply to message #384650] Fri, 08 August 2008 05:29 Go to previous message
> Hi Lorenzo,
> @Override
> hope that helps,
> Sven
>> RULE_STRING :
>> @Override
>> return rules;
>> shape
>> @Override
>> return rules;
>> overwritten...
>> thanks
>> Lorenzo
Re: [xtext] Error in the generated PartitionScanner [message #619459 is a reply to message #384650] Fri, 08 August 2008 12:47 Go to previous message
> Hi Lorenzo,
the patch here
hope this helps
Lorenzo
#P xtext.generator
@@ -103,8 +103,8 @@
�ENDIF-�
return rules;
Re: [xtext] Error in the generated PartitionScanner [message #619460 is a reply to message #384650] Fri, 08 August 2008 12:47 Go to previous message
> Hi Lorenzo,
the patch here
hope this helps
Lorenzo
#P xtext.generator
@@ -103,8 +103,8 @@
�ENDIF-�
return rules;
Re: [xtext] Error in the generated PartitionScanner [message #619462 is a reply to message #384664] Fri, 08 August 2008 12:52 Go to previous message
>> Hi Lorenzo,
> the patch here
Re: [xtext] Error in the generated PartitionScanner [message #619476 is a reply to message #384665] Wed, 13 August 2008 11:23 Go to previous message
Thank you!
>>> Hi Lorenzo,
>> the patch here
Re: [xtext] Error in the generated PartitionScanner [message #619478 is a reply to message #384779] Wed, 13 August 2008 12:35 Go to previous message
> Thank you!
>>>> Hi Lorenzo,
Re: [xtext] Error in the generated PartitionScanner [message #619970 is a reply to message #384781] Fri, 22 August 2008 04:22 Go to previous message
Member
-- Scott
Re: [xtext] Error in the generated PartitionScanner [message #620036 is a reply to message #384880] Fri, 22 August 2008 07:50 Go to previous message
regards,
Sven
> -- Scott
Re: [xtext] Error in the generated PartitionScanner [message #620047 is a reply to message #384880] Sat, 23 August 2008 13:10 Go to previous message
Previous Topic:[Epsilon][Eugenia]Multiple compartments problem
Next Topic:[AM3] Wrinting UML models with ANT plugin
Current Time: Thu May 23 15:40:44 EDT 2013
Powered by FUDForum. Page generated in 0.02520 seconds
