Home » Eclipse Projects » EclipseLink » Eclipselink not picking up database changes on refresh
Eclipselink not picking up database changes on refresh [message #384232] Sun, 07 December 2008 21:40 Go to next message
matthew simcox is currently offline matthew simcox
I have a entity association from parent->child, where a parent can have
many children (as always). I'm using eclipselink for the first time and
I'm finding that when I add/remove a new child via my RCP front end and
refresh the parent entity it doesn't pick up the changes. I can see that
the updates are occurring correctly in the oracle back end.
I've set up some manualy sysout calls that loop tell me exactly whats
being picked up from the tables when I refresh the list and i can see that
its only picking up the data from the last restart. If I restart the
changes are picked up.
This has led me to think that perhaps there is some caching going on but
I'm not sure how to change this. Any ideas?
Re: Eclipselink not picking up database changes on refresh [message #384234 is a reply to message #384232] Mon, 08 December 2008 09:11 Go to previous message
James Sutherland is currently offline James Sutherland
How are you refreshing the object? Are you using EntityManager.refresh()?
EclipseLink caches by default. To disable the shared cache use the
persistence.xml property,
"eclipselink.cache.shared.default"="false"
Although disabling the shared cache is not normally the best idea. You
can refresh an object using EntityManager.refresh() or the Query hint
"eclipselink.refresh"="true". EclipseLink also has cache invalidation,
several different caching types, clustered cache coordination, and other
options.
Are you using the same EntityManager? An EntityManager normally
represents a transaction context, and will cache all objects locally read
through it. You should normal get a new EntityManager per transaction or
per request.
James
http://www.nabble.com/EclipseLink---Users-f26658.html
James : Wiki : Book : Blog
Previous Topic:Entity must be managed to call remove
Next Topic:Why should I upgrade?
Current Time: Fri May 24 01:01:54 EDT 2013
Powered by FUDForum. Page generated in 0.01943 seconds
