Home » Eclipse Projects » EclipseLink » EJBQL translaltion problem
EJBQL translaltion problem [message #383018] Wed, 12 November 2008 06:10 Go to next message
Milos is currently offline Milos
Hi, all!
I ran into pretty interesting problem using Toplink previosly, so it turned
out that Eclipselink does the same thing.
I have EJBQL query like this (taken from Java code):
"SELECT distinct i FROM NumberTestA i WHERE ( " +
"( ( ?1 = true ) OR i.acol <> ?2 ) AND " +
" ( ( ?3 is null ) OR i.str = ?4 ) " +
") ORDER BY i.acol";
parameters 1 and 3 are set as boolean, true in case that parameters 2 and 4
are null (checked before that in java code).
Anyway, this kind of query kind of confuses our persistence provider. It
gets translated into this:
SELECT DISTINCT t1.ID, t1.DTYPE, t1.NUM, t1.STR, t1.ACOL,
t0.ACOL
FROM NUMBER_TEST t0, NUMBER_TEST t1
WHERE (((((? = ?) OR (t0.ACOL <> ?))
AND ((? IS NULL) OR (t0.STR = ?)))
AND (t0.DTYPE = ?))
AND (t1.DTYPE = ?))
ORDER BY t0.ACOL ASC
bind => [false, true, X, true, z, NumberTestA, NumberTestA]
So i get cartesian on my table, without any join condition. In case of table
with 2000 rows... You get the picture.
It is easy for me to make workaround on this, I simply split query string
into separate conditions and put them, as well as setting parameters with
bunch of if conditions, checking whether passed param is null, bu this looks
like an issue, something that confuses both Toplink and Eclipselink, so I
thought I should point to this.
Best,
Milos
Re: EJBQL translaltion problem [message #383028 is a reply to message #383018] Mon, 17 November 2008 09:54 Go to previous message
James Sutherland is currently offline James Sutherland
This seems to be a bug, please log this bug in Bugzilla.
I'm not certain why EclipseLink would generate the extra table in the from
clause, it seems related to the parameters being on the left, switching to
"true = ?1" may resolve the issue.
Please also include your changes that make it work in the bug.
James
http://www.nabble.com/EclipseLink---Users-f26658.html
James : Wiki : Book : Blog
Previous Topic:EclipseLink Test suite and Ingres
Next Topic:I must be missing something!
Current Time: Tue May 21 10:18:12 EDT 2013
Powered by FUDForum. Page generated in 0.01934 seconds
