Home » Eclipse Projects » EclipseLink » abort query
abort query [message #382786] Sun, 26 October 2008 03:28 Go to next message
Tom Eugelink is currently offline Tom Eugelink
Currently I have a user specified Eclipselink query running inside a Foxtrot "ConcurrentWorker" task, and I want to user to be able to abort it. The query naturally is either busy in the SQL (JDBC classes) or busy fetching data (Eclipselink).
The recommended approach is not possible, since I do not have a way to insert a stop-flag into either the JDBC or Eclipselink code. I try to fire a Thread.interrupt on the thread in question, but it does not abort the query.
Is it possible to abort a query (this is not a timeout)?
Re: abort query [message #382787 is a reply to message #382786] Sun, 26 October 2008 03:51 Go to previous messageGo to next message
lQuery.setHint(org.eclipse.persistence.config.QueryHints.JDB C_TIMEOUT, lJdbcTimeout);
I thought I also could have the user specify a maximum execution time up front, but the line above (set to 30 or 5 or 1) does not work. I'm using an Informix 10 database.
Tom
Re: abort query [message #382788 is a reply to message #382787] Mon, 27 October 2008 09:34 Go to previous messageGo to next message
James Sutherland is currently offline James Sutherland
Setting the query timeout is probably your best options.
Some JDBC drivers support a cancel() API, but whether this is supported is
dependent on the JDBC driver and the database. There is no API in JPA or
EclipseLink to cancel a query, so you would need to obtain the JDBC
statement to attempt to cancel it. Feel free to log an enhancement
request to have a cancel() API added to EclipseLink.
http://java.sun.com/j2se/1.5.0/docs/api/java/sql/Statement.h tml#cancel()
James
http://www.nabble.com/EclipseLink---Users-f26658.html
James : Wiki : Book : Blog
Re: abort query [message #382790 is a reply to message #382788] Mon, 27 October 2008 10:38 Go to previous messageGo to next message
Not being able to find any place to log RFE's (the Eclipselink website is somewhat confusing at times), I added it as a bug with an "RFE:" tag to the subject.
Bug 252193
I did try the QueryHints (as my second posts mentions), but that did not work either.
Re: abort query [message #382793 is a reply to message #382790] Tue, 28 October 2008 09:19 Go to previous message
In Eclipse enhancements are logged in Bugzilla with Severity set to
"enhancement"
Both timeouts and cancel are JDBC operations, if your JDBC driver and
database do not support them there is little EclipseLink can do. Try
testing the timeout or cancel using raw JDBC.
Previous Topic:Persistent Java Class Data Base Storage?
Next Topic:[not] exists
Current Time: Sun May 19 16:13:59 EDT 2013
Powered by FUDForum. Page generated in 0.01844 seconds
