Home » Eclipse Projects » EclipseLink » QueryRedirector problem (Bug/JPA)
QueryRedirector problem (Bug/JPA) [message #382540] Fri, 17 October 2008 05:29 Go to next message
Richard Eckart is currently offline Richard Eckart
Hello everybody,
we are trying to use the QueryRedirector feature of EclipseLink to
realize partially loaded entities. Imagine we have an entity type A
which has a OneToMany relation to a type B. Now we want to load A so
that only those dependend B are loaded that match a certain criteria.
There are two problems involved in this:
a) QueryRedirectors do not work if we use the JPA EntityManager.find()
method, though the JavaDoc for the QueryRedirectors state that a
ReadObject redirector should be invoked.
We assume this is a bug. EntityManagerImpl.findInternal() does not
set a redirector on the created query. Probably this has been
forgotten as the JavaDoc clearly states that it should set the
redirector.
b) We also configured redirectors on the type B expecting that when
EclipseLink loads the B entites related to A, a readAll redirector
should be invoked. This however is not the case, so that we cannot
intercept and modify the query loading of the related B entities.
Do we misunderstand the concept of redirectors here? Shouldn't they
also be able to intercept the loading of related entities? May this
also be a bug?
Richard
Re: QueryRedirector problem (Bug/JPA) [message #382543 is a reply to message #382540] Fri, 17 October 2008 09:31 Go to previous messageGo to next message
Gordon Yorke is currently offline Gordon Yorke
Member
If you migrate to EclipseLink 1.0.1 you will be able to set a default
redirector on the Entity that will be invoked for all queries on that
Entity. Look at @QueryRedirectors annotation.
--Gordon
Re: QueryRedirector problem (Bug/JPA) [message #382545 is a reply to message #382543] Fri, 17 October 2008 10:29 Go to previous messageGo to next message
Hi Gordon,
as a matter of fact we are using EclipseLink 1.0.1. As far as we can
tell after stepping through the code, what the @QueryRedirectors
annotation documentation tells us is not what is acutally happening.
Richard
> --Gordon
Re: QueryRedirector problem (Bug/JPA) [message #382763 is a reply to message #382545] Mon, 20 October 2008 14:24 Go to previous message
Member
Richard,
I am unable to reproduce your problems with the redirectors. I have
default redirectors configured and queries are being redirected to these
classes. EntityManager.find() is being redirected as are mapping queries.
With the EntityManager.find() is it possible you are getting a cache hit
and no query is being executed?
Can you provide a simple testcase?
--Gordon
Previous Topic:DescriptorEventAdapter merging and object
Next Topic:a custom number class
Current Time: Sat May 25 07:29:22 EDT 2013
Powered by FUDForum. Page generated in 0.03969 seconds
