Home » Modeling » Modeling (top-level project) » Amalgamate Models
Amalgamate Models [message #382206] Fri, 23 May 2008 10:04 Go to next message
Eclipse User
Originally posted by: zhengxie.ie.ibm.com
I have two uml models, model1 and model2. I need to add all the elements
in model2 into model1, so that the new model1 has all the elements of
model1 and model2. How can I do it?
Thanks.
Re: Amalgamate Models [message #382207 is a reply to message #382206] Fri, 23 May 2008 10:47 Go to previous messageGo to next message
Eclipse User
> Thanks.
Basicly, what I did is:
find all the Packages in model2 and add them to model1's packagedElements.
The problem is:
The applied stereotypes are lost.
Re: Amalgamate Models [message #382208 is a reply to message #382207] Sat, 24 May 2008 09:33 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
Zheng,
Please use the UML newsgroup, which I've added to the "to" list of the
reply, for questions about UML.
Zheng Xie wrote:
>> elements in model2 into model1, so that the new model1 has all the
>> elements of model1 and model2. How can I do it?
>> Thanks.
> packagedElements.
> The problem is:
Re: Amalgamate Models [message #382211 is a reply to message #382208] Wed, 28 May 2008 09:47 Go to previous message
james bruck is currently offline james bruck
Hi Zheng,
For a general "copy" method you can have a look at EcoreUtil.copy(EObject
eObject).
The UMLUtil PackageMerger uses this to copy elements.
Alternatively have a look UML2Util.getAllContents() to get the contents of
one object. A defensive copy of the contents can be made.
- James.
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:g195bt$ct7$1@build.eclipse.org...
> Zheng,
>>> Thanks.
>> packagedElements.
>> The problem is:
Re: Amalgamate Models [message #607531 is a reply to message #382206] Fri, 23 May 2008 10:47 Go to previous message
Eclipse User
> Thanks.
The problem is:
Re: Amalgamate Models [message #607532 is a reply to message #382207] Sat, 24 May 2008 09:33 Go to previous message
Zheng,
>> Thanks.
> packagedElements.
> The problem is:
Re: Amalgamate Models [message #607535 is a reply to message #382208] Wed, 28 May 2008 09:47 Go to previous message
Hi Zheng,
eObject).
- James.
> Zheng,
>>> Thanks.
>> packagedElements.
>> The problem is:
Previous Topic:Add New Resource Storage Mechanism
Next Topic:missing tracing tab
Current Time: Fri May 24 21:24:26 EDT 2013
Powered by FUDForum. Page generated in 0.01706 seconds
