Home » Modeling » Modeling (top-level project) » DSLs, language models and parsers
DSLs, language models and parsers [message #375866] Sun, 15 January 2006 09:41 Go to next message
Francisco Gortázar is currently offline Francisco Gortázar
We have been aware of your proposal, and we wonder whether our work
would fit into the scope of the project. Our work is concerned with DSLs
and language models, specially those DLSs which are intended to have
textual notation. From a language model of the DSL annotated with some
syntactic information a parser is automatically generated.
Giving that we are concerned with the definition of models and textual
notations, and that textual notation for models is within the scope of
the project, we think our approach could be of benefit for the project.
What do you think?
Patxi Gortázar
Re: DSLs, language models and parsers [message #375867 is a reply to message #375866] Sun, 15 January 2006 18:22 Go to previous messageGo to next message
Frederic Plante is currently offline Frederic Plante
Hi Patxi,
Thanks for your interest for the modeling project!
If I understand your approach properly and do not attempt to read too much
between the lines, it seems your work could fall within the scope of the
modeling project, but would require some realignment.
As is, the approach is making use of a model describing a textual notation
to generate code that fulfills a task unrelated to modeling; parsing the
textual notation. This is an application of two modeling technologies:
modeling and transformation. This is out of scope since we are looking for
tooling/framework to support modeling activities, as opposed to their
application.
However, an in-scope alternative could be the creation of some tooling that
would take as input a domain meta-model and a textual notation model. It
would generate a text editor capable of editing instances of the meta-model
using the textual notation. This is more-or-less a textual notation version
of the Graphical Modeling Framework (GMF) project.
I hope this clarifies.
- Fred
"Francisco Gort
Re: DSLs, language models and parsers [message #375871 is a reply to message #375867] Sun, 05 February 2006 15:11 Go to previous messageGo to next message
Eclipse User
Originally posted by: constantine.plotnikov.gmail.com
--------------000804050500080800070000
Content-Type: text/plain; charset=windows-1252; format=flowed
I
Re: DSLs, language models and parsers [message #375873 is a reply to message #375871] Sun, 05 February 2006 17:51 Go to previous messageGo to next message
Artem Tikhomirov is currently offline Artem Tikhomirov
Oh, there seems to be a lot of interest in the area of DSL textual
notation. Would be great to get all interested parties at EclipseCon (e.g.
at the next short talk:
http://canuck.gda.itesm.mx/eclipsezilla/show_bug.cgi?id=438) to discuss
approaches or even join efforts :)
Best wishes,
Artem Tikhomirov
"Constantie Plotnikov" <constantine.plotnikov@gmail.com> wrote in message
news:ds5m5n$c33$1@utils.eclipse.org...
> that
> meta-model
> version
I
Re: DSLs, language models and parsers [message #375875 is a reply to message #375873] Mon, 06 February 2006 01:02 Go to previous messageGo to next message
Eclipse User
I guess it is just a time for DSL toolkits to hatch out. I generally
very fond of idea of discussing approaches and joining efforts.
However it is very unlikely that I will manage to get to EclipseCON this
year due to a number of different reasons, but I will check this again.
So is it possible for discussion to happen on this group for a while? I
would like see some details on your approach.
What I'm interested are:
- samples of textual notation (including complex cases
like expressions);
- textual notation definition details;
- some architectual principles like extensibility model
(reusable language modules and creating new languages
that modify some language just a bit).
And I'm ready answer questions about my approach. I have tried to answer
some questions in documents and samples in the package. But I'm sure
that that you will have different questions. Also the questions will
give me focus for the next documentation update in the package.
Constantine
> Best wishes,
> Artem Tikhomirov
>>that
>>meta-model
>>version
> I’m currently working on open source project that has a goal
> to create a language definition framework that can be used as
> textual DSL construction kit. And it fits the quoted description
> quote well and can be considered as textual notation design
> tool. The framework is named Extensible Term Language (ETL).
> This language definition framework is very similar by architecture
> to XML.
Re: DSLs, language models and parsers [message #375877 is a reply to message #375871] Mon, 06 February 2006 03:57 Go to previous messageGo to next message
Constantine Plotnikov is currently offline Constantine Plotnikov
Member
I have unpacked documentation and XML files generated from samples on
project web site at
http://etl.sourceforge.net/etl-java-0_2_0/doc/readme.html
Constantine
EMF Expression Language [message #381901 is a reply to message #375866] Wed, 07 May 2008 11:12 Go to previous messageGo to next message
Mickael Istria is currently offline Mickael Istria
I'm looking for something that would be able to do on EMF the same kind
of things that XPath can do on XML.
The aim would be to use this expression language in XML file describing
the model to reference some EMF entities.
Do you know whether such an expression language exists for EMF?
Mickael
Re: EMF Expression Language [message #381902 is a reply to message #381901] Wed, 07 May 2008 11:31 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
Mickael,
The JET project has XPath support against EMF objects. The OCL project
supports EMF object navigation as well. And of course EMF's fragment
paths are XPath-like and are supported by all models.
Mickael Istria wrote:
> Hello,
> kind of things that XPath can do on XML.
> describing the model to reference some EMF entities.
> Mickael
Re: EMF Expression Language [message #381903 is a reply to message #381902] Tue, 13 May 2008 03:09 Go to previous messageGo to next message
Sven Efftinge is currently offline Sven Efftinge
Also oAW's expression language can be used.
The latest version (4.3) has just been released under
www.eclipse.org/modeling/gmt/oaw
regards,
Sven
Ed Merks schrieb:
> Mickael,
>> Hello,
>> Regards,
>> Mickael
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
Re: EMF Expression Language [message #381904 is a reply to message #381903] Tue, 13 May 2008 10:01 Go to previous message
--------------090407000103090205070907
Sven,
I think you mean
http://www.eclipse.org/gmt/oaw/
It's hard to find any documentation.
Be careful with the work release since when you talk about things
released at Eclipse, that implies a release review has taken place.
Probably you mean "made available" when you say "released"?
> regards,
> Sven
> Ed Merks schrieb:
>> Mickael,
>> project supports EMF object navigation as well. And of course EMF's
>> fragment paths are XPath-like and are supported by all models.
>>> Hello,
>>> Regards,
>>> Mickael
<html>
<head>
</head>
Sven,<br>
<br>
I think you mean<br>
<blockquote><a href="http://www.eclipse.org/gmt/oaw/">http://www.eclipse.org/gmt/oaw/</a><br>
</blockquote>
It's hard to find any documentation.<br>
<br>
released at Eclipse, that implies a release review has taken place.&nbsp;
Probably you mean "made available" when you say "released"?<br>
<br>
<br>
<blockquote cite="mid:g0bequ$5im$1@build.eclipse.org" type="cite">Also
<br>
<a class="moz-txt-link-abbreviated" href="http://www.eclipse.org/modeling/gmt/oaw">www.eclipse.org/modeling/gmt/oaw</a>
<br>
<br>
regards,
<br>
Sven
<br>
<br>
Ed Merks schrieb:
<br>
<blockquote type="cite">Mickael,
<br>
<br>
The JET project has XPath support against EMF objects.&nbsp; The OCL project
supports EMF object navigation as well.&nbsp; And of course EMF's fragment
<br>
<br>
<br>
<br>
<blockquote type="cite">Hello,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Mickael
<br>
</blockquote>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------090407000103090205070907--
Re: DSLs, language models and parsers [message #560567 is a reply to message #375866] Sun, 15 January 2006 18:22 Go to previous message
Hi Patxi,
application.
- Fred
"Francisco Gort
Re: DSLs, language models and parsers [message #560594 is a reply to message #375867] Sun, 05 February 2006 15:11 Go to previous message
Eclipse User
I
Re: DSLs, language models and parsers [message #560601 is a reply to message #375871] Sun, 05 February 2006 17:51 Go to previous message
Best wishes,
Artem Tikhomirov
> that
> meta-model
> version
I
Re: DSLs, language models and parsers [message #560607 is a reply to message #375873] Mon, 06 February 2006 01:02 Go to previous message
Eclipse User
like expressions);
Constantine
> Best wishes,
> Artem Tikhomirov
>>that
>>meta-model
>>version
> to XML.
Re: DSLs, language models and parsers [message #560615 is a reply to message #375871] Mon, 06 February 2006 03:57 Go to previous message
Member
project web site at
Constantine
EMF Expression Language [message #606579 is a reply to message #375866] Wed, 07 May 2008 11:12 Go to previous message
Mickael
Re: EMF Expression Language [message #606581 is a reply to message #381901] Wed, 07 May 2008 11:31 Go to previous message
Mickael,
> Hello,
> Mickael
Re: EMF Expression Language [message #606583 is a reply to message #381902] Tue, 13 May 2008 03:09 Go to previous message
regards,
Sven
Ed Merks schrieb:
> Mickael,
>> Hello,
>> Regards,
>> Mickael
Re: EMF Expression Language [message #606586 is a reply to message #381903] Tue, 13 May 2008 10:01 Go to previous message
Sven,
I think you mean
> regards,
> Sven
> Ed Merks schrieb:
>> Mickael,
>>> Hello,
>>> Regards,
>>> Mickael
<html>
<head>
</head>
Sven,<br>
<br>
</blockquote>
<br>
<br>
<br>
<br>
<br>
<br>
regards,
<br>
Sven
<br>
<br>
Ed Merks schrieb:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Mickael
<br>
</blockquote>
</blockquote>
</blockquote>
<br>
</body>
</html>
Previous Topic:EMF - JPA ?
Next Topic:[Announce] Papyrus component proposal
Current Time: Sat May 18 19:39:50 EDT 2013
Powered by FUDForum. Page generated in 0.02505 seconds
