| Exception [EclipseLink-30005] - Persistence FAILED [message #381265] |
Fri, 05 September 2008 13:05  |
Originally posted by: www.floranet.eu.gmail.com
Hi there to everyone,
i start a eclipselink study but i get this issue all the times.
In my classpath i got a user librarie with
(eclipselink.jar,javax.persistence_1.0.0.0.jar,
mysql-connector-java-5.1.6). I configure my persistence.xml like this:
<persistence version="1.0"
xmlns="http://java.sun.com/xml/ns/persistence"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://java.sun.com/xml/ns/persistence
http://java.sun.com/xml/ns/persistence/persistence_1_0.xsd">
<persistence-unit name="eu.floranet.jpa.link"
transaction-type="RESOURCE_LOCAL">
<description>org.eclipse.persistence.jpa.PersistenceProvider,
javax.persistence.Persistence</description>
<provider>org.eclipse.persistence.jpa.PersistenceProvider</provider >
<class>
eu.link.temp.CptExposicao</class>
<exclude-unlisted-classes>false</exclude-unlisted-classes>
<properties>
<property name="eclipselink.logging.level" value="INFO"/>
<property name="eclipselink.jdbc.driver"
value="com.mysql.jdbc.Driver"/>
<property name="eclipselink.jdbc.url"
value="jdbc:mysql://server:3306/database"/>
<property name="eclipselink.jdbc.password" value="pass"/>
<property name="eclipselink.jdbc.user" value="user"/>
<property name="eclipselink.jdbc.read-connections.min" value="1"/>
<property name="eclipselink.jdbc.write-connections.min" value="1"/>
<property name="eclipselink.target-database" value="MySql"/>
</properties>
</persistence-unit>
</persistence>
And got this error in console:
Exception Description: An exception was thrown while searching for
persistence archives with ClassLoader:
sun.misc.Launcher$AppClassLoader@11b86e7
Internal Exception: java.lang.RuntimeException:
Local Exception Stack:
Exception [EclipseLink-30005] (Eclipse Persistence Services - 1.0 (Build
1.0 - 20080707)):
org.eclipse.persistence.exceptions.PersistenceUnitLoadingExc eption
org.eclipse.persistence.exceptions.PersistenceUnitLoadingExc eption.exceptionSearchingForPersistenceResources(Persistence UnitLoadingException.java:121)
org.eclipse.persistence.jpa.PersistenceProvider.createEntity ManagerFactory(PersistenceProvider.java:117)
org.eclipse.persistence.jpa.PersistenceProvider.createEntity ManagerFactory(PersistenceProvider.java:64)
javax.persistence.Persistence.createEntityManagerFactory(Per sistence.java:83)
javax.persistence.Persistence.createEntityManagerFactory(Per sistence.java:60)
at eu.link.temp.MainExpo.createEMF(MainExpo.java:26)
at eu.link.temp.MainExpo.start(MainExpo.java:36)
at eu.link.temp.MainExpo.main(MainExpo.java:20)
Caused by: java.lang.RuntimeException: java.lang.NullPointerException
org.eclipse.persistence.internal.jpa.metadata.xml.XMLEntityM appingsReader.read(XMLEntityMappingsReader.java:67)
org.eclipse.persistence.internal.jpa.metadata.xml.XMLEntityM appingsReader.read(XMLEntityMappingsReader.java:105)
org.eclipse.persistence.internal.jpa.metadata.MetadataProces sor.loadStandardMappingFiles(MetadataProcessor.java:343)
org.eclipse.persistence.internal.jpa.metadata.MetadataProces sor.loadMappingFiles(MetadataProcessor.java:271)
org.eclipse.persistence.internal.jpa.deployment.PersistenceU nitProcessor.buildPersistentClassSetFromXMLDocuments(Persist enceUnitProcessor.java:127)
org.eclipse.persistence.internal.jpa.deployment.PersistenceU nitProcessor.buildClassSet(PersistenceUnitProcessor.java:90)
org.eclipse.persistence.internal.jpa.deployment.JPAInitializ er.callPredeploy(JPAInitializer.java:83)
org.eclipse.persistence.internal.jpa.deployment.JPAInitializ er.initPersistenceUnits(JPAInitializer.java:149)
org.eclipse.persistence.internal.jpa.deployment.JPAInitializ er.initialize(JPAInitializer.java:135)
org.eclipse.persistence.jpa.PersistenceProvider.createEntity ManagerFactory(PersistenceProvider.java:104)
... 6 more
Caused by: java.lang.NullPointerException
org.eclipse.persistence.platform.xml.XMLPlatformFactory.getX MLPlatformClass(XMLPlatformFactory.java:75)
org.eclipse.persistence.platform.xml.XMLPlatformFactory.getX MLPlatform(XMLPlatformFactory.java:106)
org.eclipse.persistence.internal.oxm.record.DOMUnmarshaller. <init>(DOMUnmarshaller.java:65)
org.eclipse.persistence.oxm.platform.DOMPlatform.newPlatform Unmarshaller(DOMPlatform.java:38)
org.eclipse.persistence.oxm.XMLUnmarshaller.initialize(XMLUn marshaller.java:84)
org.eclipse.persistence.oxm.XMLUnmarshaller.<init>(XMLUnmarshaller.java:78)
org.eclipse.persistence.oxm.XMLContext.createUnmarshaller(XM LContext.java:271)
org.eclipse.persistence.internal.jpa.metadata.xml.XMLEntityM appingsReader.read(XMLEntityMappingsReader.java:63)
... 15 more
Exception in thread "main" Local Exception Stack:
1.0 - 20080707)):
... 6 more
... 15 more
If i change the provider to javax.persistence.Persistence other
different issue i got:
javax.persistence.PersistenceException: No Persistence provider for
EntityManager named eu.floranet.jpa.link
javax.persistence.Persistence.createEntityManagerFactory(Per sistence.java:89)
Exception in thread "main" javax.persistence.PersistenceException: No
Persistence provider for EntityManager named eu.floranet.jpa.link
Could someone help me?
Thanks in advance....
| Re: Exception [EclipseLink-30005] - Persistence FAILED [message #381271 is a reply to message #381266] |
Mon, 08 September 2008 04:28   |
Doug Clarke escreveu:
> Miguel,
> Please ensure your persistence.xml file is located at:
> META-INF/persistence.xml on your classpath. Can you also provide any
> details of how your are initiating your JPA access?
> Doug
Hi Doug,
the persistence file is located at META-INF and the file contain this code:
package eu.flora.temp;
import javax.persistence.EntityManager;
import javax.persistence.EntityManagerFactory;
import javax.persistence.Persistence;
public class MainP {
private EntityManagerFactory emf;
* @param args
// TODO Auto-generated method stub
MainP p = new MainP();
p.start();
private EntityManagerFactory createEMF() {
try {
return Persistence.createEntityManagerFactory("PLink");
} catch (RuntimeException e) {
System.out.println("Persistence.createEMF FAILED: "
+ e.getMessage());
e.printStackTrace();
throw e;
public void start(){
this.emf = this.createEMF();
EntityManager em = this.emf.createEntityManager();
CptEntidades c = em.find(CptEntidades.class, 1);
System.out.println("Name: " + c.getEntidadeNome());
em.close();
| Re: Exception [EclipseLink-30005] - Persistence FAILED [message #381272 is a reply to message #381271] |
Mon, 08 September 2008 09:28   |
Miguel Ramos escreveu:
>> Miguel,
>> Doug
> Hi Doug,
> * @param args
> public static void main(String[] args) {
> p.start();
> try {
> + e.getMessage());
> throw e;
> em.close();
After analyse the eclipselink.jar and read some articles i applied the
osgi bundles and after that everything works fine. I've just create a
USER_LIBRARIE with the jars bundled by osgi and change the provider in
the persistence.xml by org.eclipse.persistence.jpa.PersistenceProvider.
| Re: Exception [EclipseLink-30005] - Persistence FAILED [message #381275 is a reply to message #381274] |
Mon, 08 September 2008 10:12  |
James escreveu:
> This is odd, the null-pointer you are seeing is occurring because the
> EclipseLink class loader is null. From the java.lang.Class comment this
> can only occur on some JVMs if the bootstrap loader was used to load the
> class.
> How are you launching your Java program, and what JVM are you using (and
> what are your JVM args)?
> -- James
I use jdk1.6.0_03 and launch from eclipse with default args, and you
where right about the null-pointer. The fact of using a user librarie in
eclipse the class's aren't load and occur the class loader null. I just
link the jars in jlib of eclipselink (not using USER_LIBRARIE) and
voilâ.... Working.
THanks,
FUDForum. Page generated in 0.01812 seconds
