| [TCS] multi-step reference resolution [message #380825] |
Fri, 04 January 2008 08:50  |
Andy Carpenter Messages: 144 Registered: July 2009 |
We are trying to process an existing DSL that has a
nested block structure but which allows references
to objects in sibling blocks by specifying the path to
the object, cf. referencing objects in Java packages.
For example
block0 {
block1 {
define v1;
block2 {
define v2;
v2 = block1.v1;
Here, the reference to v1 in block2 has to use the
prefix block1 to make the name v1 visible. Is there
a variant of the referesTo operation that can be used
to resolve such references, or is there a way to
overload the implementation of referesTo to perform
such resolution?
Thanks for any help
Andy.
Dr Andy Carpenter
School of Computer Science,
University of Manchester, Manchester M13 9PL, UK
Email: Andy.Carpenter@manchester.ac.uk
Tel: +44 161 275 6168
Fax: +44 161 275 6280
| Re: [TCS] multi-step reference resolution [message #380831 is a reply to message #380825] |
Mon, 07 January 2008 09:42   |
Originally posted by: mikael.barbero.gmail.com
Hi Andy,
TCS currently does not support this kind of reference resolution.
refersTo only allow to specify the attribute that will be used to
identify the referred element but it does not allow to specify this kind
of "namespace path".
Can you open a bug about this feature request? Thanks.
Mikael
> For example
> block0 {
> block1 {
> define v1;
> block2 {
> define v2;
> v2 = block1.v1;
> such resolution?
> Thanks for any help
> Andy.
Mikaël Barbero - PhD Candidate
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssinière
44322 Nantes Cedex 3 - France
tel. +33 2 51 12 58 08 /\ cell.+33 6 07 63 19 00
email: Mikael.Barbero@{gmail.com, univ-nantes.fr}
http://www.sciences.univ-nantes.fr/lina/atl/
| Re: [TCS] multi-step reference resolution [message #380843 is a reply to message #380831] |
Wed, 09 January 2008 09:55   |
To complete my previous answer. There may be a work around but you have
to change your metamodel (if you can). I suppose your metamodel is
something like this (in KM3):
class Block {
attribute name : String;
reference subblocks[*] ordered container : Block;
reference statements[*] ordered container : Statement;
abstract class Statement {}
class VariableDef extends Statement {
attribute varName : String;
class VariableRef {
reference varDef : VariableDef;
reference ownerblock[0-1] : Block; -- This to support the path to
sibling blocks
class Assignement extends Statement {
reference lhs : VariableRef;
reference rhs : VariableRef;
Then, your TCS should look like:
template Assignement
: lhs "=" rhs
template VariableRef
: (isDefined(ownerblock) ? ownerblock {refersTo = name} ".")
varDef{refersTo = varName, lookIn=ownerblock}
Hope this helps,
Mikael
Mikaël Barbero wrote:
> Hi Andy,
> Best regards,
> Mikael
>> For example
>> block0 {
>> block1 {
>> define v1;
>> block2 {
>> define v2;
>> v2 = block1.v1;
>> such resolution?
>> Thanks for any help
>> Andy.
| Re: [TCS] multi-step reference resolution [message #380845 is a reply to message #380843] |
Wed, 09 January 2008 10:44   |
I committed a sample project to illustrate this workaround (and
corrected some errors there are in my previous post). It is available
there:
http://dev.eclipse.org/viewcvs/indextech.cgi/org.eclipse.gmt /org.eclipse.gmt.tcs/syntaxes/MSRT/
and also added a "samples langugages" section in the TCS Zoo:
http://wiki.eclipse.org/TCS/Zoo
Mikael
> class Block {
> class VariableRef {
> sibling blocks
> : lhs "=" rhs
> Hope this helps,
> Mikael
>> Hi Andy,
>> kind of "namespace path".
>> Best regards,
>> Mikael
>>> For example
>>> block0 {
>>> block1 {
>>> define v1;
>>> block2 {
>>> define v2;
>>> v2 = block1.v1;
>>> such resolution?
>>> Thanks for any help
>>> Andy.
| Re: [TCS] multi-step reference resolution [message #611111 is a reply to message #380825] |
Hi Andy,
Mikael
> For example
> block0 {
> block1 {
> define v1;
> block2 {
> define v2;
> v2 = block1.v1;
> such resolution?
> Thanks for any help
> Andy.
| Re: [TCS] multi-step reference resolution [message #611160 is a reply to message #380831] |
class Block {
class VariableRef {
sibling blocks
: lhs "=" rhs
Hope this helps,
Mikael
> Hi Andy,
> Best regards,
> Mikael
>> For example
>> block0 {
>> block1 {
>> define v1;
>> block2 {
>> define v2;
>> v2 = block1.v1;
>> such resolution?
>> Thanks for any help
>> Andy.
| Re: [TCS] multi-step reference resolution [message #611162 is a reply to message #380843] |
there:
Mikael
> class Block {
> class VariableRef {
> sibling blocks
> : lhs "=" rhs
> Hope this helps,
> Mikael
>> Hi Andy,
>> Best regards,
>> Mikael
>>> For example
>>> block0 {
>>> block1 {
>>> define v1;
>>> block2 {
>>> define v2;
>>> v2 = block1.v1;
>>> such resolution?
>>> Thanks for any help
>>> Andy.
FUDForum. Page generated in 0.03339 seconds
