Home » Modeling » GMT (Generative Modeling Technologies) » [TCS] More than one syntax construction per class AND optional keywords
[TCS] More than one syntax construction per class AND optional keywords [message #380835] Tue, 08 January 2008 05:09 Go to next message
Gustavo Cabral is currently offline Gustavo Cabral
Hi everyone,
Is it possible to define more than one syntax definition per class
of the DSL metamodel. For example, something like this:
-- KM3
class NounNamePlural {
attribute name : String;
attribute plural : String;
-- TCS (Solution 2)
template NounNamePlural addToContext
: name "is a noun and its plural form is" plural "."
: name "is a noun; its plural form is" plural "."
-- TCS (Solution 2)
I know the code\syntax above doesn't work! Is there any alternative syntax
I can use? In ANTLR, I would use the | constructor. What would it be in
TCS?
The second question is: is it possible to have optional constructor? In
ANTLT it would be ( "optional terminal or nonterminal" )?. In TCS? I would
like to have:
: name "is a noun and its plural" ("form")? is" plural "."
for instance.
Best regards and thank you,
Gustavo Cabral
Re: [TCS] More than one syntax construction per class AND optional keywords [message #380836 is a reply to message #380835] Tue, 08 January 2008 05:38 Go to previous messageGo to next message
Sorry for my premature questioning. I downloaded the TCS dsl project
(CVS) and found out how to define syntax alternatives using the
[[ alt1 | alt2 .... | altN ]] constructor, like in:
: [[ name "is a noun and its plural form is " plural "."
I still don't know how to define optional elements in my
syntax definition. :( Anyone?
regards,
Gustavo
Re: [TCS] More than one syntax construction per class AND optional keywords [message #380838 is a reply to message #380836] Tue, 08 January 2008 06:33 Go to previous message
Eclipse User
Originally posted by: quentin.glineur.obeo.fr
--------------030105070206010408000408
Hi Gustavo,
As far as I know, the square brakets are only for model to text
production. The alternatives should work without them.
For optional elements, the question mark is used.
For example:
--KM3
attribute plural[O..1] : String;
--TCS
template NounNamePlural addToContext :
isDefined(plural)?
name "is a noun and its plural form is " plural "." :
name "is a noun and its plural form is " name "s."
Quentin GLINEUR
Gustavo Cabral a
Re: [TCS] More than one syntax construction per class AND optional keywords [message #611153 is a reply to message #380835] Tue, 08 January 2008 05:38 Go to previous message
regards,
Gustavo
Re: [TCS] More than one syntax construction per class AND optional keywords [message #611155 is a reply to message #380836] Tue, 08 January 2008 06:33 Go to previous message
Eclipse User
Hi Gustavo,
For example:
--KM3
--TCS
isDefined(plural)?
Quentin GLINEUR
Gustavo Cabral a
Previous Topic:[TCS] More than one syntax construction per class AND optional keywords
Next Topic:[TCS] UML 2.1.1 TCS
Current Time: Fri May 24 12:25:06 EDT 2013
Powered by FUDForum. Page generated in 0.01741 seconds
