Home » Modeling » GMT (Generative Modeling Technologies) » [TCS]:beginning TCS with Eclipse
[TCS]:beginning TCS with Eclipse [message #379837] Fri, 05 October 2007 07:55 Go to next message
Eclipse User
Originally posted by: joseph.brooth.gmail.com
hi,
I am new with TCS
I tested the TCSToolkit project(Eclipse3.3+ATL2.0+EMF2.3) but I found the
problems of SampleDSL_InjectorCreation.xml and here the extract of the
errors.
BUILD FAILED
/home/ydkiouak/Desktop/eclipse/Test/SampleDSL/SampleDSL_Inje ctorCreation.xml:5:
The following error occurred while executing this line:
/home/ydkiouak/Desktop/eclipse/Test/TCSToolkit/TCS2JAR/build .xml:23: The
/home/ydkiouak/Desktop/eclipse/Test/TCSToolkit/TCS2JAR/build .xml:120:
Unable to determine generated class
Total time: 3 seconds
then I tried to start with TCS/Language Project but I didn't has to find
the AMMAScripts, and AMMACore projects ???
and also how to configure the fishier build.properties
regards
Joseph
Re: [TCS]:beginning TCS with Eclipse [message #379840 is a reply to message #379837] Fri, 05 October 2007 08:46 Go to previous messageGo to next message
Freddy Allilaire is currently offline Freddy Allilaire
Hi Joseph,
TCS sample project hasn't moved yet to the last versions of ATL & TCS.
For examples, please take a look to the TCS Zoo:
http://wiki.eclipse.org/TCS/Zoo
Concerning the second point, we have just updated the TCS/Language
Project wiki page (http://wiki.eclipse.org/TCS/Language_Project).
Normally you will find now all the necessary information.
HTH.
Freddy.
Joseph Brouth a écrit :
> hi,
> I am new with TCS I tested the TCSToolkit
> project(Eclipse3.3+ATL2.0+EMF2.3) but I found the problems of
> SampleDSL_InjectorCreation.xml and here the extract of the errors.
> BUILD FAILED
> regards
> Joseph
Freddy Allilaire - ATLAS Group (INRIA & LINA)
http://www.sciences.univ-nantes.fr/lina/atl/contrib/allilair e
Re: [TCS]:beginning TCS with Eclipse [message #379847 is a reply to message #379840] Fri, 05 October 2007 10:47 Go to previous messageGo to next message
Eclipse User
thank you for informations
but i'm the problem with checked out the AMMAScripts and AMMACore.
is necessary to add CVS Repository ?
so yes I find how I can the configuration with this CVS(the host, the
standard connection.............)
thnx
Joseph
Re: [TCS]:beginning TCS with Eclipse [message #379854 is a reply to message #379847] Sat, 06 October 2007 12:45 Go to previous messageGo to next message
Frédéric Jouault is currently offline Frédéric Jouault
Currently, apart from manually downloading the files from the viewcvs,
you have to use CVS to get the projects. We will offer an easier
download later.
The AMMAScripts and AMMACore projects are in:
server: dev.eclipse.org
repository: /cvsroot/technology
connect annonymously using pserver
Then, checkout the two projects available in:
org.eclipse.gmt/org.eclipse.gmt.tcs/scripts/
Frédéric Jouault
Re: [TCS]:beginning TCS with Eclipse [message #379901 is a reply to message #379854] Mon, 08 October 2007 05:28 Go to previous messageGo to next message
Eclipse User
Originally posted by: joseph.Brooth.gmail.com
yes I added the All scripts in my workspace but I have remarks for the
following points:
******* build.properties (you can copy and paste
/SampleLanguage/build.properties and modify it).*******
for this file I recovered with one project of ZOO TCS because I did'nt
find "/SampleLanguage/build.properties"
how to configure this file?
for me I notched "Custom build"!!
Es this that it is correct?.
******** In the "Targets" tab:--Set "During a Clean" to target "clean"
I dont arrive to fair this point because I found the zone "During a Clean"
desactivate and text posted inside "Builder is not set to run for this
build kind" same thing in the fields "After A clean" and "Auto build"
I tested with the button "Set Targets" but always this zone is desactivate?
how I should make to activate?
finaly for excute my TCS Projects(Model-To project -- Text) how I must
make?
Thank you for your Helps.
Joseph
Re: [TCS]:beginning TCS with Eclipse [message #380366 is a reply to message #379901] Fri, 16 November 2007 11:49 Go to previous message
Hi Joseph,
You should simply specify the name of your DSL, and associated file
extension:
dsl.name=<language name, same as project name>
dsl.extension=<associated file extension>
> Clean" desactivate and text posted inside "Builder is not set to run for
> this build kind" same thing in the fields "After A clean" and "Auto
build"
desactivate?
Does the configuration point to the correct ant script?
> make?
> Joseph
You could start from the sample injection ant script available at the
bottom of http://wiki.eclipse.org/TCS/Language_Project
Frédéric Jouault
Re: [TCS]:beginning TCS with Eclipse [message #608042 is a reply to message #379837] Fri, 05 October 2007 08:46 Go to previous message
Hi Joseph,
HTH.
Freddy.
> hi,
> BUILD FAILED
> regards
> Joseph
Re: [TCS]:beginning TCS with Eclipse [message #608047 is a reply to message #379840] Fri, 05 October 2007 10:47 Go to previous message
Eclipse User
thnx
Joseph
Re: [TCS]:beginning TCS with Eclipse [message #608052 is a reply to message #379847] Sat, 06 October 2007 12:45 Go to previous message
download later.
Frédéric Jouault
Re: [TCS]:beginning TCS with Eclipse [message #608063 is a reply to message #379854] Mon, 08 October 2007 05:28 Go to previous message
Eclipse User
following points:
make?
Joseph
Re: [TCS]:beginning TCS with Eclipse [message #608259 is a reply to message #379901] Fri, 16 November 2007 11:49 Go to previous message
Hi Joseph,
extension:
build"
desactivate?
> make?
> Joseph
Frédéric Jouault
Previous Topic:[MOFScript] Navigable Asociation
Next Topic:[TCS]:Create a Language project!!
Current Time: Fri May 24 19:14:15 EDT 2013
Powered by FUDForum. Page generated in 0.08969 seconds
