| [MOFScript] Navigable Asociation [message #380331] |
Thu, 08 November 2007 06:30  |
Originally posted by: javjimgon.alum.us.es
I would like to know when a end association isNavigable. On order to
generate an attribute only in the class which is in the navigable end of
the association.
Thank you in advance!!
Javier Jimenez
| Re: [MOFScript] Navigable Asociation [message #380362 is a reply to message #380334] |
Wed, 14 November 2007 03:47   |
Gøran K. Olsen escribió:
> Hello Javier,
> Considering UML.
> I have seen different implementations of this so it depends on how your
> model is created.
> Using e.g. a model created in Papyrus UML or IBM RSM you traverse your
> ownedAttributes and checks if association !null.
> texttransformation NewTrans(in uml:"http://www.eclipse.org/uml2/2.1.0/UML")
> uml.Class::main () {
> stdout.println("Class Name: " + self.name)
> self.ownedAttribute->forEach(p:uml.Property | p.association!=null){
> stdout.println("Navigable Association: " + p.name)
> stdout.println("Navigable AssociationType: " + p.type.name)
> on:
> class_0
> Class_1 ------------>Class_0
> Gives output:
> Class Name: Class_0
> Class Name: Class_1
> Navigable Association: class_0
> Navigable AssociationType: Class_0
> /Gøran
> "Javier Jimenez" <javjimgon@alum.us.es> wrote in message
> news:fgurvs$938$1@build.eclipse.org...
>> Hello,
>> the association.
>> Javier Jimenez
Hello Gøran,
thanks for your answer. Finally it was a problem of the UML editor that
I use (Topcased). There is a bug and when you tick the 'isNavigable'
option in an association, you can not save the model.
Other question there is more documentation about MOFScript. I can only
find the user manual.
Javier Jimenez
| Re: [MOFScript] Navigable Asociation [message #380364 is a reply to message #380362] |
Wed, 14 November 2007 09:08  |
Gøran K. Olsen Messages: 184 Registered: July 2009 |
Hi Javier,
The user manual and the built in help functionality Help->Help Contents->
MOFScript should cover the functionality that is available.
There are also some simple example transformations in the repository folder
of the MOFScript editor plugin.
Since MOFScript handles models based on EMF, when it comes to navigating the
different metamodels e.g. UML, you will have to consult the metamodel
specification.
/G
| Re: [MOFScript] Navigable Asociation [message #608249 is a reply to message #380331] |
Fri, 09 November 2007 08:38  |
Hello Javier,
Considering UML.
model is created.
on:
class_0
Gives output:
Class Name: Class_0
Class Name: Class_1
/G
| Re: [MOFScript] Navigable Asociation [message #608256 is a reply to message #380334] |
> Hello Javier,
> Considering UML.
> model is created.
> on:
> class_0
> Gives output:
> Class Name: Class_0
> Class Name: Class_1
> /Gøran
>> Hello,
>> the association.
>> Javier Jimenez
Hello Gøran,
Javier Jimenez
| Re: [MOFScript] Navigable Asociation [message #608257 is a reply to message #380362] |
Hi Javier,
specification.
/G
FUDForum. Page generated in 0.01818 seconds
