Home » Modeling » MDT (Model Development Tools) » UML2 to Java class without any ECore dependencies
UML2 to Java class without any ECore dependencies [message #380008] Sat, 21 March 2009 10:56 Go to next message
joel is currently offline joel
Hi all,
I'm trying to generate my Java domain class from my UML2 model. For that
purpose I did a class diagram using Eclipse UML2 plugin, I generated its
related EMF model and then loaded it into a genmodel, as given here:
http://dev.eclipse.org/newslists/news.eclipse.modeling.mdt.u ml2tools/msg00703.html
The problem is that each class are extending EObject, etc. As I understood
(I'm new to EMF), EMF seems to be a "model of a model" definition.
On my side, I only want to get my UML diagram as Java class without having
any EObject inheritence. Is there a way to simply achieve this ?
Thank you in advance.
Joël
Re: UML2 to Java class without any ECore dependencies [message #380009 is a reply to message #380008] Sat, 21 March 2009 11:14 Go to previous message
Ed Merks is currently offline Ed Merks
Joël,
Please don't cross post the same question to multiple groups with
separate postings.
joel wrote:
> Hi all,
> that purpose I did a class diagram using Eclipse UML2 plugin, I
> generated its related EMF model and then loaded it into a genmodel, as
> given here:
> understood (I'm new to EMF), EMF seems to be a "model of a model"
> definition.
> having any EObject inheritence. Is there a way to simply achieve this ?
> Best regards,
> Joël
Re: UML2 to Java class without any ECore dependencies [message #597546 is a reply to message #380008] Sat, 21 March 2009 11:14 Go to previous message
Joël,
separate postings.
joel wrote:
> Hi all,
> given here:
> definition.
> Best regards,
> Joël
Previous Topic:UML2 to Java class without any ECore dependencies
Next Topic:[UML2] Tutorials on use-case diagrams?
Current Time: Sun May 26 05:14:18 EDT 2013
Powered by FUDForum. Page generated in 0.02021 seconds
