Home » Modeling » Modeling (top-level project) » IllegalArgumentException: The feature 'artifact' is not a valid feature, when load resource
| IllegalArgumentException: The feature 'artifact' is not a valid feature, when load resource [message #379659] |
Wed, 21 February 2007 07:40  |
Originally posted by: zhengxie.ie.ibm.com
When the following resource is loaded, the parser throws an exception:
Can you see what is wrong with the resource? It was deserialised by
save() on the resource.
Thanks a lot!
Zheng
<mrd:RepositoryModel xmi:version="2.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:mdp="http://com.mtools.repository/defauld"
xmlns:mrd="http://com.mtools.repository" name="Analysis"
id="_cT2SMsGVEdubFJnviccVQw" date="21-Feb-2007 11:22:33"
version="_cT2SM8GVEdubFJnviccVQw">
<classification xsi:type="mrd:RepositoryModelClassification"/>
<solution xsi:type="mrd:RepositoryModelContents">
<artifact xsi:type="mdp:_Artifact"
artifactId="_i3BrUMGVEdubFJnviccVQw">
<artifact xsi:type="mrd:CoreModelArtifact" name="IFW Summary
Requirements Model" artifactId="_Hh1w67hyEdu4-fVe9xIyRQ"
packageURI="http://www.eclipse.org/uml2/2.0.0/UML">
<reference xsi:type="mdp:_Reference"><element
href=" rasset://_Hh1wsLhyEdu4-fVe9xIyRQ/934336C5-1AE7-4F31-E873-FCA A7C8EC07E/industryModels/analysis/D53FD5B2-6BAF-F45D-716E-2F 9A043C257D.ma#_FX2leLhyEdu4-fVe9xIyRQ"/><value> industryModels/analysis/D53FD5B2-6BAF-F45D-716E-2F9A043C257D .ma </value></reference>
<description xsi:type="mdp:_Description"><value>IFW Summary
Requirements Model</value></description>
</artifact>
</artifact>
artifactId="_i3BrUcGVEdubFJnviccVQw">
Requirements Model" artifactId="_cT2SNMGVEdubFJnviccVQw"
href=" analysis/D53FD5B2-6BAF-F45D-716E-2F9A043C257D.ma#_FX2leLhyEd u4-fVe9xIyRQ "/><value> industryModels/analysis/D53FD5B2-6BAF-F45D-716E-2F9A043C257D .ma </value></reference>
<artifactDependency xsi:type="mdp:_ArtifactDependency"
artifact="//@artifact.0/@artifact.0"/>
</artifact>
</artifact>
artifactId="_jEk_IMGVEdubFJnviccVQw">
<artifact xsi:type="mrd:CoreModelArtifact" name="NamingStandard"
artifactId="_Hh1w7rhyEdu4-fVe9xIyRQ"
packageURI="http:///com/ibm/db/models/naming/naming.ecore">
href=" rasset://_Hh1wsLhyEdu4-fVe9xIyRQ/934336C5-1AE7-4F31-E873-FCA A7C8EC07E/industryModels/analysis/7ABFBB51-3F50-6412-4210-BE DA9FD0F746.ndm#_Gt9WUIICEdmDSdxbPbsTjQ"/><value> industryModels/analysis/7ABFBB51-3F50-6412-4210-BEDA9FD0F746 .ndm </value></reference>
<description xsi:type="mdp:_Description"/>
</artifact>
</artifact>
artifactId="_jEk_IcGVEdubFJnviccVQw">
artifactId="_i3BrUsGVEdubFJnviccVQw"
href="analysis/NamingStandard.ndm#_Gt9WUIICEdmDSdxbPbsTjQ"/ ><value>industryModels/analysis/NamingStandard.ndm</value> </reference>
artifact="//@artifact.2/@artifact.0"/>
</artifact>
</artifact>
artifactId="_jJNAcMGVEdubFJnviccVQw">
<artifact xsi:type="mrd:CoreModelArtifact" name="Domain Model"
artifactId="_jEk_IsGVEdubFJnviccVQw"
packageURI="http:///com/ibm/db/models/logical/logical.ecore">
href="analysis/Domain
Model.ddm#_TzD848GVEdubFJnviccVQw"/><value>industryModels/analysis/Domain
Model.ddm</value></reference>
</artifact>
</artifact>
artifactId="_jTx4wMGVEdubFJnviccVQw">
<artifact xsi:type="mrd:CoreModelArtifact" name="IFW System of
Record Model" artifactId="_Hh1w5bhyEdu4-fVe9xIyRQ"
href=" rasset://_Hh1wsLhyEdu4-fVe9xIyRQ/934336C5-1AE7-4F31-E873-FCA A7C8EC07E/industryModels/analysis/02045AAC-985E-0711-ABE0-C7 2AAD108DBB.ma#_FX2lZrhyEdu4-fVe9xIyRQ"/><value> industryModels/analysis/02045AAC-985E-0711-ABE0-C72AAD108DBB .ma </value></reference>
<description xsi:type="mdp:_Description"><value>IFW System of
Record Model</value></description>
</artifact>
</artifact>
artifactId="_jTx4wcGVEdubFJnviccVQw">
Record Model" artifactId="_jJNAccGVEdubFJnviccVQw"
href="analysis/IFW System of Record
Model.ldm#_FX2lZrhyEdu4-fVe9xIyRQ"/><value>industryModels/analysis/IFW
System of Record Model.ldm</value></reference>
artifact="//@artifact.5/@artifact.0"/>
</artifact>
</artifact>
artifactId="_jhVzoMGVEdubFJnviccVQw">
<artifact xsi:type="mrd:CoreModelArtifact" name="IFW Summary and
Analysis Model" artifactId="_Hh1w6LhyEdu4-fVe9xIyRQ"
href=" rasset://_Hh1wsLhyEdu4-fVe9xIyRQ/934336C5-1AE7-4F31-E873-FCA A7C8EC07E/industryModels/analysis/4A66BCCB-3FB3-273D-C1F5-F1 6E84ACAF7A.ma#_FX2lb7hyEdu4-fVe9xIyRQ"/><value> industryModels/analysis/4A66BCCB-3FB3-273D-C1F5-F16E84ACAF7A .ma </value></reference>
<description xsi:type="mdp:_Description"><value>IFW Summary and
Analysis Model</value></description>
</artifact>
</artifact>
artifactId="_jhVzocGVEdubFJnviccVQw">
Analysis Model" artifactId="_jTx4wsGVEdubFJnviccVQw"
href="analysis/IFW Summary and Analysis
Model.ldm#_FX2lb7hyEdu4-fVe9xIyRQ"/><value>industryModels/analysis/IFW
Summary and Analysis Model.ldm</value></reference>
artifact="//@artifact.7/@artifact.0"/>
</artifact>
</artifact>
</solution>
<profile xsi:type="mrd:Analysis"/>
</mrd:RepositoryModel>
| Re: IllegalArgumentException: The feature 'artifact' is not a valid feature, when load resource [message #379664 is a reply to message #379661] |
Wed, 21 February 2007 09:24   |
Thanks Ed.
This is a RAS manifest file. It seems that the artifact dependency stuff
cause the problem. If I manually remove the artifact dependency, then
the manifest can be loaded as an asset.
Zheng
Ed Merks wrote:
> Zheng,
> This question would be better asked on the EMF newsgroup, which I've
> added to the "to" list. Without knowing the model itself, and without a
> stack trace, it's hard to say what might be wrong.
>> Thanks a lot!
>> Zheng
>> <?xml version="1.0" encoding="UTF-8"?>
>> xmlns:xmi="http://www.omg.org/XMI"
>> </artifact>
>> </artifact>
>> </artifact>
>> </artifact>
>> </artifact>
>> </artifact>
>> </artifact>
>> </artifact>
>> </artifact>
>> </artifact>
>> </artifact>
>> </artifact>
>> </artifact>
>> </artifact>
>> and Analysis Model</value></description>
>> </artifact>
>> </artifact>
>> </artifact>
>> </artifact>
>> </solution>
| Re: IllegalArgumentException: The feature 'artifact' is not a valid feature, when load resource [message #379666 is a reply to message #379664] |
Wed, 21 February 2007 09:44   |
Ed Merks Messages: 24529 Registered: July 2009 |
Zheng,
I know nothing about what a RAS manifest file is. Given that the
message is complaining about the "artifact" feature, it's quite apparent
this is related to that feature's use in the serialization. Does your
comment mean you've solved the problem or are you still asking a
question? Without seeing the model and without a stack trace, I can't
think of anything to say that might be helpful.
Zheng Xie wrote:
> Thanks Ed.
> stuff cause the problem. If I manually remove the artifact dependency,
> then the manifest can be loaded as an asset.
> Zheng
> Ed Merks wrote:
>> Zheng,
>> without a stack trace, it's hard to say what might be wrong.
>>> exception: IllegalArgumentException: The feature 'artifact' is not a
>>> valid feature
>>> Thanks a lot!
>>> Zheng
>>> </artifact>
>>> </artifact>
>>> </artifact>
>>> </artifact>
>>> name="NamingStandard" artifactId="_Hh1w7rhyEdu4-fVe9xIyRQ"
>>> </artifact>
>>> </artifact>
>>> name="NamingStandard" artifactId="_i3BrUsGVEdubFJnviccVQw"
>>> </artifact>
>>> </artifact>
>>> </artifact>
>>> </artifact>
>>> of Record Model</value></description>
>>> </artifact>
>>> </artifact>
>>> </artifact>
>>> </artifact>
>>> and Analysis Model" artifactId="_Hh1w6LhyEdu4-fVe9xIyRQ"
>>> </artifact>
>>> </artifact>
>>> and Analysis Model" artifactId="_jTx4wsGVEdubFJnviccVQw"
>>> </artifact>
>>> </artifact>
>>> </solution>
| Re: IllegalArgumentException: The feature 'artifact' is not a valid feature, when load resource [message #379964 is a reply to message #379666] |
Mon, 05 March 2007 06:07  |
Hi Ed,
I found for the artifactDependency it has to be
artifact="//@solution/@artifact.0/@artifact.0"/>
Because "artifact" is contained in "solution".
What went wrong was when the RepositoryModelContents is created, it is
set into the RepositoryModel, but not in the way that RepositoryModel is
its container. So when the model is serialized, it is as
.....artifact="//@artifact.0/@artifact.0"...
not
....artifact="//@solution/@artifact.0/@artifact.0"...
Zheng
Ed Merks wrote:
> Zheng,
> Zheng Xie wrote:
>> Thanks Ed.
>> Zheng
>> Ed Merks wrote:
>>> Zheng,
>>>> valid feature
>>>> Thanks a lot!
>>>> Zheng
>>>> </artifact>
>>>> </artifact>
>>>> </artifact>
>>>> </artifact>
>>>> </artifact>
>>>> </artifact>
>>>> </artifact>
>>>> </artifact>
>>>> </artifact>
>>>> </artifact>
>>>> </artifact>
>>>> </artifact>
>>>> </artifact>
>>>> </artifact>
>>>> </artifact>
>>>> </artifact>
>>>> </artifact>
>>>> </artifact>
>>>> </solution>
| Re: IllegalArgumentException: The feature 'artifact' is not a valid feature, when load resource [message #586715 is a reply to message #379659] |
Wed, 21 February 2007 08:45  |
Zheng,
> Thanks a lot!
> Zheng
> </artifact>
> </artifact>
> </artifact>
> </artifact>
> </artifact>
> </artifact>
> </artifact>
> </artifact>
> </artifact>
> </artifact>
> </artifact>
> </artifact>
> </artifact>
> </artifact>
> </artifact>
> </artifact>
> </artifact>
> </artifact>
> </solution>
| Re: IllegalArgumentException: The feature 'artifact' is not a valid feature, when load resource [message #586725 is a reply to message #379661] |
Thanks Ed.
Zheng
Ed Merks wrote:
> Zheng,
>> Thanks a lot!
>> Zheng
>> </artifact>
>> </artifact>
>> </artifact>
>> </artifact>
>> </artifact>
>> </artifact>
>> </artifact>
>> </artifact>
>> </artifact>
>> </artifact>
>> </artifact>
>> </artifact>
>> </artifact>
>> </artifact>
>> </artifact>
>> </artifact>
>> </artifact>
>> </artifact>
>> </solution>
| Re: IllegalArgumentException: The feature 'artifact' is not a valid feature, when load resource [message #586739 is a reply to message #379664] |
Zheng,
Zheng Xie wrote:
> Thanks Ed.
> Zheng
> Ed Merks wrote:
>> Zheng,
>>> valid feature
>>> Thanks a lot!
>>> Zheng
>>> </artifact>
>>> </artifact>
>>> </artifact>
>>> </artifact>
>>> </artifact>
>>> </artifact>
>>> </artifact>
>>> </artifact>
>>> </artifact>
>>> </artifact>
>>> </artifact>
>>> </artifact>
>>> </artifact>
>>> </artifact>
>>> </artifact>
>>> </artifact>
>>> </artifact>
>>> </artifact>
>>> </solution>
| Re: IllegalArgumentException: The feature 'artifact' is not a valid feature, when load resource [message #589925 is a reply to message #379666] |
Hi Ed,
not
Zheng
Ed Merks wrote:
> Zheng,
> Zheng Xie wrote:
>> Thanks Ed.
>> Zheng
>> Ed Merks wrote:
>>> Zheng,
>>>> valid feature
>>>> Thanks a lot!
>>>> Zheng
>>>> </artifact>
>>>> </artifact>
>>>> </artifact>
>>>> </artifact>
>>>> </artifact>
>>>> </artifact>
>>>> </artifact>
>>>> </artifact>
>>>> </artifact>
>>>> </artifact>
>>>> </artifact>
>>>> </artifact>
>>>> </artifact>
>>>> </artifact>
>>>> </artifact>
>>>> </artifact>
>>>> </artifact>
>>>> </artifact>
>>>> </solution>
Current Time: Sat May 18 21:38:46 EDT 2013
Powered by FUDForum. Page generated in 0.02251 seconds
