| [Epsilon] Performance [message #378266] |
Thu, 21 June 2007 04:33  |
Aleksander Bandelj Messages: 98 Registered: July 2009 |
Member |
Epsilon is quite slow on large models. Reason seems not to lie in
language interpreter itself, but in model access. Major cause is name
lookup in NameExecutor#execute. Every variable access first looks for
model elements (slow) only then in current variable scope. Looking up
variable first speeds things up by incredible amount. I wouldn't mind
variable-first semantics. Current (model-first) one should be enforced
by checking for name shadowing conflict before interpretation.
Another proposal: it would be nice that empty name model access always
accesses first registered model, even if more than one model is
registered. This way, scripts written for processing of single model
would still work on multiple model resource sets (I have several use
cases for this). This would also resembe how EMF editors work (first
resource is active one). It's a simple change in
EolModelRepository#getModelByName
-a
| Re: [Epsilon] Performance [message #378267 is a reply to message #378266] |
Thu, 21 June 2007 05:41  |
Dimitrios Kolovos Messages: 1772 Registered: July 2009 |
Hi Aleksander,
Thanks for your insightful comments. Comments below:
I've fixed this. Now it checks for a model element type first only if
the name includes a "!".
I can see this one introducing some confusion :) but I think the
trade-off is good so I've also fixed it.
A cleaner approach for future versions would be to enable dynamic
activation/deactivation of models by adding respective methods to the
EolModel class :
DB.activate();
Table.allInstances.println();
UML.activate(); -- Activates UML, deactivates DB
Class.allInstances.println();
> -a
Dimitrios
| Re: [Epsilon] Performance [message #602078 is a reply to message #378266] |
Hi Aleksander,
EolModel class :
DB.activate();
> -a
Dimitrios
FUDForum. Page generated in 0.01584 seconds
