| [AM3] Which version of ATL needed? [message #378196] |
Fri, 15 June 2007 16:43  |
Lutz Wrage Messages: 59 Registered: July 2009 |
Member |
I've installed ATL and AM3 from cvs. ATL works fine. However, I can't
inject a km3 into ecore. When I select the operation from the context
menu on any km3 file I get the attached exception.
My understanding in that the ebnf injector is part of ATL but the km3
parser is part of AM3. Is there a problem using the latest versions from
cvs together? Do I need a certain old version of ATL to run the km3
injector?
Lutz
java.lang.NoSuchMethodError:
org.atl.engine.injectors.ebnf.EBNFInjector2.create(Ljava/lan g/String;ZZ)Lorg/eclipse/m2m/atl/engine/vm/nativelib/ASMMode lElement;
at org.atl.engine.injectors.ebnf.KM3Parser.metamodel(Unknown Source)
at org.atl.engine.injectors.ebnf.KM3Parser.main(Unknown Source)
at org.atl.engine.injectors.ebnf.ANTLR2Wrapper.parse(ANTLR2Wrap per.java:70)
org.atl.engine.injectors.ebnf.EBNFInjector2.performImportati on(EBNFInjector2.java:150)
org.atl.engine.injectors.ebnf.EBNFInjector2.performImportati on(EBNFInjector2.java:120)
org.atl.engine.injectors.ebnf.EBNFInjector2.performImportati on(EBNFInjector2.java:116)
org.eclipse.gmt.am3.dsls.km3.KM3Projector.getEMFKM3FromFile( KM3Projector.java:224)
at org.eclipse.gmt.am3.dsls.km3.actions.KM32Ecore$1.run(KM32Eco re.java:58)
| Re: [AM3] Which version of ATL needed? [message #378265 is a reply to message #378198] |
Wed, 20 June 2007 09:19  |
Member |
I've updated from cvs and it works now.
- Lutz
Frédéric Jouault wrote:
> Hello,
> We are currently working on the ATL and AM3 parsers. The current CVS
> HEAD is not guaranteed to work at all time.
> However, the KM3 plugin has been updated yesterday, and should now work.
> Frédéric Jouault
>> from cvs together? Do I need a certain old version of ATL to run the
>> km3 injector?
>> Thanks,
>> Lutz
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
>> at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
>> at java.lang.reflect.Method.invoke(Unknown Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
| Re: [AM3] Which version of ATL needed? [message #602003 is a reply to message #378196] |
Sat, 16 June 2007 15:08  |
Frédéric Jouault Messages: 572 Registered: July 2009 |
Frédéric Jouault
> injector?
> Lutz
> at
> at
> at
> at
> at
> at
| Re: [AM3] Which version of ATL needed? [message #602064 is a reply to message #378198] |
Member |
- Lutz
> Hello,
> Frédéric Jouault
>> km3 injector?
>> Thanks,
>> Lutz
>> at
>> at
>> at
>> at
>> at
>> at
FUDForum. Page generated in 0.01688 seconds
