| [Epsilon] mddi adapter or stand-alone [message #378185] |
Fri, 15 June 2007 06:33  |
Originally posted by: hein..fokus.fraunhofer
I wonder if there is already an Epsilon adapter for the eclipse mddi
project or is there a tutorial how Epsilon can be used stand-alone?
Thanks in advance
Christian
| Re: [Epsilon] mddi adapter or stand-alone [message #378262 is a reply to message #378261] |
Mon, 18 June 2007 05:31  |
Dimitrios Kolovos Messages: 1772 Registered: July 2009 |
Hi Christian,
> Thanks for your help, I'm interested mainly in ETL and EML. BTW Is there
> an overview (paper, article) about the languages features that ETL
> provides and which not?
Documentation on the syntax of ETL can be found in
http://dev.eclipse.org/viewcvs/indextech.cgi/org.eclipse.gmt /epsilon/org.epsilon.eclipse.help/index.html.
Also it'd probably be worth playing with the basic language of Epsilon
(EOL) first as all the languages of the platform (such as ETL and EML)
inherit its syntax and capabilities.
(comparision with ATL,QVT ...?)
Unfortunately, we don't have a document containing a comprehensive
comparison between ETL and other transformation languages yet (mainly
due to lack of time to do that :) ). However, there is an older post in
the newsgroup that you may find useful:
news://news.eclipse.org:119/f05059$t45$1@build.eclipse.org
(Needlessly to say, should you choose to use ETL in parallel with some
other transformation language it would be really interesting to hear
back on your experiences)
> Cheers,
> Christian
Dimitrios
| Re: [Epsilon] mddi adapter or stand-alone [message #602037 is a reply to message #378261] |
Hi Christian,
> Cheers,
> Christian
Dimitrios
FUDForum. Page generated in 0.01896 seconds
