Home » Modeling » MDT (Model Development Tools) » [Announce] MDT 1.1 development plan
| Re: [Announce] MDT 1.1 development plan [message #377171 is a reply to message #377168] |
Mon, 24 September 2007 11:16   |
Originally posted by: lucas.bigeardel.anyware-tech.com
Kenn Hussey a écrit :
> A draft of the development plan for MDT 1.1, targeted for June 2008 as part
> of the Ganymede simultaneous release, has been posted at
> http://www.eclipse.org/modeling/mdt/docs/plans/mdt_project_p lan_1_1.html.
> Feedback is welcome.
> Kenn
I would suggest adding an dev plan item for a reusable OCL widget for
edition purpose.
[OCL Tools component]:{Reusable OCL editor widget}
My idea would be to give user possibility to embbed such OCL widget as
part of their tools UI (eg: inside wizard page, console page, tabbed
propeties page, search page, ....).
Maybe could we inspire ourselve from the OCL interpreter example coming
from EMFT Query, having a MDT OCLViewer with M1/M2 support for OCL
editing, based on the MDT OCL Parser.
I already have a need for such feature in [EMFT Search] and can offer
reasonible contribution effort for that.
regards,
| Re: [Announce] MDT 1.1 development plan [message #377720 is a reply to message #377177] |
Tue, 25 September 2007 03:58   |
> Lucas,
> I'm sure Miguel will give your suggestion (and contribution!) due
> consideration when he puts together more detailed development plans for the
> Ganymede release... at this point, the OCL Tools component has yet to be
> provisioned. :(
> Kenn
Kenn,
I'll take some time to talk with Miguel about that.
cheers,
- Lucas
> "lb" <lucas.bigeardel@anyware-tech.com> wrote in message
> news:fd8kcr$e9d$1@build.eclipse.org...
>>> part of the Ganymede simultaneous release, has been posted at
>>> Kenn
>> edition purpose.
>> regards,
| Re: [Announce] MDT 1.1 development plan [message #377726 is a reply to message #377168] |
Tue, 25 September 2007 11:53   |
> Kenn
Kenn,
could we consider a UML2 tools Diagram Search contribution (ie: EMFT
Search based) as possibly part of MDT UML2Tools ?
I could propose a patch for such feature, in a form of plugin offering
popup menu for selected X class in a Class Diagram for :
- associations references to class X
- compositions references to class X
- aggregations references to class X
- more ?
I'm not sure where this plugin should take place MDT/? or EMFT Search/UML2/?
In the one hand this would seems natural to me to have it somewhere in
UML2Tools, in the other hand I do understand this would add a very
optional dependency to UML2Tools.
Any idea ?
regards,
- Lucas
| Re: [Announce] MDT 1.1 development plan [message #377987 is a reply to message #377168] |
Wed, 07 November 2007 01:41   |
Nicolas Rouquette Messages: 132 Registered: July 2009 |
Hi Kenn,
One area where the UML API is particularly weak on is protecting itself
in cases where exceptions are triggered precisely because something has
made the model ill-formed - e.g., a circular containment hierarchy, a
circular generalization hierarchy, etc... In some cases (e.g., circular
containment induced from a package merge operation gone bad), we can
even induce an infinite loop in the exception handling code that
attempts to undo the mess. I observed these things in the Eclipse 3.2
environment I work with (uml 2.0.4) From the CVS logs, I am not sure if
the issues are still there or not. If they are, is this the sort of
issue that could be considered for the MDT 1.1 plan?
-- Nicolas.
> Kenn
| Re: [Announce] MDT 1.1 development plan [message #377988 is a reply to message #377987] |
Wed, 07 November 2007 10:46  |
james bruck Messages: 1724 Registered: July 2009 |
Hi Nicolas,
If possible, could you please raise specific defects (with steps to
reproduce the problem).
Contributions from the community regarding filling out the various
validation functions is always welcomed ;).
- James.
"Nicolas Rouquette" <nicolas.rouquette@jpl.nasa.gov> wrote in message
news:47315E30.4040903@jpl.nasa.gov...
> Hi Kenn,
> One area where the UML API is particularly weak on is protecting itself in
> cases where exceptions are triggered precisely because something has made
> the model ill-formed - e.g., a circular containment hierarchy, a circular
> generalization hierarchy, etc... In some cases (e.g., circular containment
> induced from a package merge operation gone bad), we can even induce an
> infinite loop in the exception handling code that attempts to undo the
> mess. I observed these things in the Eclipse 3.2 environment I work with
> (uml 2.0.4) From the CVS logs, I am not sure if the issues are still there
> or not. If they are, is this the sort of issue that could be considered
> Cheers,
> -- Nicolas.
>> Kenn
| Re: [Announce] MDT 1.1 development plan [message #574360 is a reply to message #377168] |
> Kenn
edition purpose.
regards,
| Re: [Announce] MDT 1.1 development plan [message #576591 is a reply to message #377177] |
> Lucas,
> provisioned. :(
> Kenn
Kenn,
cheers,
- Lucas
>>> Kenn
>> edition purpose.
>> regards,
| Re: [Announce] MDT 1.1 development plan [message #576771 is a reply to message #377168] |
> Kenn
Kenn,
- more ?
Any idea ?
regards,
- Lucas
| Re: [Announce] MDT 1.1 development plan [message #578412 is a reply to message #377168] |
Hi Kenn,
-- Nicolas.
> Kenn
| Re: [Announce] MDT 1.1 development plan [message #578429 is a reply to message #377987] |
Hi Nicolas,
- James.
> Hi Kenn,
> Cheers,
> -- Nicolas.
>> Kenn
Current Time: Wed May 22 15:32:55 EDT 2013
Powered by FUDForum. Page generated in 0.07839 seconds
