| [UML] UML equivalent EcoreUtil.UsageCrossReferencer [message #377727] |
Tue, 25 September 2007 12:17  |
Originally posted by: lucas.bigeardel.anyware-tech.com
is there a UML equivalent to EcoreUtil.UsageCrossReferencer ?
I would need to compute references to a UML Class and dont really see
tha best way to achieve that.
I guess a possible way would be to process UML Class at the meta level
taking advantage of its Ecore nature. Another way would be to use OCL
Expression.
Maybe a way in between exist, using an UML utility, but couldn't find a
solution.
Any help is welcome.
regards,
- Lucas
| Re: [UML] UML equivalent EcoreUtil.UsageCrossReferencer [message #377728 is a reply to message #377727] |
Tue, 25 September 2007 13:59  |
Kenn Hussey Messages: 1616 Registered: July 2009 |
Lucas,
This question belong on the UML2 newsgroup (copied). Try
UML2Util.getNonNavigableInverseReferences(EObject) or
UML2Util.getInverseReferences(EObject).
Kenn
"lb" <lucas.bigeardel@anyware-tech.com> wrote in message
news:fdbcat$fal$1@build.eclipse.org...
> I would need to compute references to a UML Class and dont really see tha
> Expression.
> solution.
> regards,
> - Lucas
| Re: [UML] UML equivalent EcoreUtil.UsageCrossReferencer [message #576836 is a reply to message #377727] |
Lucas,
Kenn
> Expression.
> solution.
> regards,
> - Lucas
FUDForum. Page generated in 0.01779 seconds
