Home » Modeling » GMT (Generative Modeling Technologies) » [epsilon] error using EXEED
[epsilon] error using EXEED [message #377719] Wed, 16 May 2007 09:15 Go to next message
Sylvain is currently offline Sylvain
Member
Hi all,
I'm interrested in using Exeed from epsilon component. I've installed
everything from the eclipse website, but I can't edit a XMI file.
In the log I get this error:
!ENTRY org.eclipse.ui 4 0 2007-05-16 14:56:25.578
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.NoClassDefFoundError: antlr/TokenStream
org.epsilon.eol.models.AbstractEolModel.<init>(AbstractEolModel.java:86)
at org.epsilon.eol.models.emf.EmfModel.<init>(EmfModel.java:40)
org.epsilon.eclipse.dt.exeed.InMemoryEmfModel.<init>(InMemoryEmfModel.java:8)
org.epsilon.eclipse.dt.exeed.ExeedEditor.createPages(ExeedEd itor.java:89)
org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:283)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:663)
looks like I need antlr but how to add it ??
please help !
Sylvain
Sylvain
Re: [epsilon] error using EXEED [message #378000 is a reply to message #377719] Wed, 16 May 2007 09:36 Go to previous messageGo to next message
Dimitrios Kolovos is currently offline Dimitrios Kolovos
Hi Sylvain,
You are right; ANTLR is missing. To add it you need to follow the
instructions provided in
http://www.eclipse.org/gmt/epsilon/doc/PluginInstallation.pd f
Dimitrios
Sylvain wrote:
> Hi all,
> !STACK 0
> at
> at
> at
> at
> at
> please help !
> Sylvain
Re: [epsilon] error using EXEED [message #378001 is a reply to message #378000] Wed, 16 May 2007 10:06 Go to previous message
Member
Hi Dimitrios !
Thanks for this pointer,
it works now !
Sylvain
> Hi Sylvain,
> Cheers,
> Dimitrios
> Sylvain wrote:
>> Hi all,
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> please help !
>> Sylvain
Sylvain
Re: [epsilon] error using EXEED [message #596960 is a reply to message #377719] Wed, 16 May 2007 09:36 Go to previous message
Hi Sylvain,
Dimitrios
Sylvain wrote:
> Hi all,
> !STACK 0
> at
> at
> at
> at
> at
> please help !
> Sylvain
Re: [epsilon] error using EXEED [message #596975 is a reply to message #378000] Wed, 16 May 2007 10:06 Go to previous message
Member
Hi Dimitrios !
it works now !
Sylvain
> Hi Sylvain,
> Cheers,
> Dimitrios
> Sylvain wrote:
>> Hi all,
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> please help !
>> Sylvain
Sylvain
Previous Topic:[epsilon] error using EXEED
Next Topic:[Epsilon] Using OCL in Meta-Model level
Current Time: Mon May 20 02:08:56 EDT 2013
Powered by FUDForum. Page generated in 0.03377 seconds
