| [OAW] dynamic evaluation of templates [message #376862] |
Tue, 17 April 2007 07:21  |
Markus Herrmannsdoerfer Messages: 50 Registered: July 2009 |
Member |
I want to save my templates in a database, so I can only access them as
a string. All parameters (e.g. metamodel, model, ...) for the template
will also be provided from the memory. Is it possible to
programmatically expand such a template with OAW?
Thanks in advance.
Markus Herrmannsdörfer
| Re: [OAW] dynamic evaluation of templates [message #376871 is a reply to message #376862] |
Sun, 22 April 2007 16:40  |
Sven Efftinge Messages: 1667 Registered: July 2009 |
this is not supported out of the box. however you could provide a
respective implementation of a resourceloader (in the workflow project),
which loads the inputstreams from the db (the default one uses a
classloader)
hope that helps,
Sven
Markus Herrmannsdoerfer wrote:
> Thanks in advance.
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
| Re: [OAW] dynamic evaluation of templates [message #580393 is a reply to message #376862] |
classloader)
hope that helps,
Sven
> Thanks in advance.
FUDForum. Page generated in 0.02264 seconds
