| using bridge build Nov1, log entry about "AuditSourceID" [message #36432] |
Thu, 08 November 2007 14:21  |
Jesse Pangburn Messages: 166 Registered: July 2009 |
With the Nov 1 version of the bridge installer I get log entries that seem
to be warnings when I submit a document:
<ns2:log xmlns:ns2="http://type.bridge.ohf.eclipse.org"><ns3:item
xmlns:ns3="http://localhost/bridge/services/ohf-bridge-wrapped">2007-11-08T11:04:48.497-08:00
Defaulting to IP Address for AuditSourceID. This should be set by calling
setAuditSourceId.</ns3:item><ns4:item
xmlns:ns4="http://localhost/bridge/services/ohf-bridge-wrapped">2007-11-08T11:04:52.753-08:00
setAuditSourceId.</ns4:item><ns5:item
xmlns:ns5="http://localhost/bridge/services/ohf-bridge-wrapped">2007-11-08T11:04:52.783-08:00
setAuditSourceId.</ns5:item></ns2:log>
This "setAuditSourceId" seems to be something you can only do through the
API. I can't find anything in the Bridge's wsdl to indicate you can set
this. I checked the rhio.xsd to see if there was a way to set it for a
rhio, but there isn't (which makes sense because it doesn't seem like it
should be a rhio setting).
Maybe the level of this message could be lower so when we turn the log
level to WARN, we don't get this message in the bridge? Or specifically
call the setAuditSourceID in the bridge2API code so it doesn't generate
the warning message at all- since maybe WARN is the right level message
for API users?
thanks,
Jesse
| Re: using bridge build Nov1, log entry about "AuditSourceID" [message #37605 is a reply to message #36517] |
Tue, 20 November 2007 18:28  |
Matthew Davis Messages: 268 Registered: July 2009 |
Right now, the AuditSourceId is being set from the
SessionContext.UserApplicationName value.
However, since this is only really relevant for the HL7-based
transactions, I have added a new field to SessionContext:
AuditSourceId. This will now call ATNA and set the value within the
context scope.
I have also renamed the SessionContext.User field to
SessionContext.InitiatingUser. This makes the usage of the field now
align more directly with the ATNA API.
Both of these changes constitute an API change in the Bridge and will
require a regeneration of any WSDL proxies that you may be using.
-Matt
Jesse Pangburn wrote:
> Hi Sarah,
> Bug is submitted as "Bug 209258"
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=209258
> Thanks for the clarification that it won't impact any tests!
> Jesse
> Sarah Knoop wrote:
>> Hi Jesse,
>> This was an oversight on our part and you should be able to submit the
>> audit source ID via the bridge. Please submit a bug to bugzilla with
>> the information below. This will not inhibit your MESA testing
>> what-so-ever. Being able to set the audit source ID is "nice" but not
>> required for these tests.
>> Thanks!
>> - Sarah
>>> Hi,
>>> seem to be warnings when I submit a document:
>>> calling setAuditSourceId.</ns3:item><ns4:item
>>> calling setAuditSourceId.</ns4:item><ns5:item
>>> calling setAuditSourceId.</ns5:item></ns2:log>
>>> the API. I can't find anything in the Bridge's wsdl to indicate you
>>> can set this. I checked the rhio.xsd to see if there was a way to
>>> set it for a rhio, but there isn't (which makes sense because it
>>> doesn't seem like it should be a rhio setting).
>>> log level to WARN, we don't get this message in the bridge? Or
>>> specifically call the setAuditSourceID in the bridge2API code so it
>>> doesn't generate the warning message at all- since maybe WARN is the
>>> right level message for API users?
>>> thanks,
>>> Jesse
| Re: using bridge build Nov1, log entry about "AuditSourceID" [message #582869 is a reply to message #36432] |
Thu, 08 November 2007 14:45  |
No real name Messages: 292 Registered: July 2009 |
Hi Jesse,
audit source ID via the bridge. Please submit a bug to bugzilla with the
information below. This will not inhibit your MESA testing what-so-ever.
Being able to set the audit source ID is "nice" but not required for
these tests.
Thanks!
- Sarah
> the API. I can't find anything in the Bridge's wsdl to indicate you can
> set this. I checked the rhio.xsd to see if there was a way to set it
> for a rhio, but there isn't (which makes sense because it doesn't seem
> for API users?
> thanks,
> Jesse
| Re: using bridge build Nov1, log entry about "AuditSourceID" [message #582892 is a reply to message #36461] |
Thu, 08 November 2007 15:43  |
Hi Sarah,
Jesse
Sarah Knoop wrote:
> Hi Jesse,
> these tests.
> Thanks!
> - Sarah
>> for API users?
>> thanks,
>> Jesse
| Re: using bridge build Nov1, log entry about "AuditSourceID" [message #583322 is a reply to message #36517] |
context scope.
-Matt
> Hi Sarah,
> Jesse
> Sarah Knoop wrote:
>> Hi Jesse,
>> Thanks!
>> - Sarah
>>> Hi,
>>> thanks,
>>> Jesse
FUDForum. Page generated in 0.09197 seconds
