| xText Startup Questions [message #375958] |
Sat, 17 February 2007 17:35  |
Originally posted by: Randy_Simons.msn.com
I want to try out xText, so started with a really simple grammar:
Entity :
"entity" name=ID;
But I still get a warning message:
...//my.dsl/src-gen//org/example/dsl/parser/mydsl.g:128: warning:lexical
nondeterminism between alts 2 and 3 of block upon
...//my.dsl/src-gen//org/example/dsl/parser/mydsl.g:128: k==1:'\r'
...//my.dsl/src-gen//org/example/dsl/parser/mydsl.g:128: k==2:'\n'
k==3:'\u0003'..'\ufffe'
k==4:'\u0003'..'\ufffe'
k==5:<end-of-token>,'\u0003'..'\ufffe'
k==6:<end-of-token>,'\u0003'..'\ufffe'
How can something so simple be nondeterministic?
Second question: Assuming this warning isn't enough to cause editor
generation to fail, how do I run the generated editor. The tutorial
says something about Eclipse knowing to use the editor for any file with
the right extension (.dsl), but that doesn't seem to work on the example
I'm trying. Am I missing some configuration step?
Thanks for any help.
Randy Simons
| Re: xText Startup Questions [message #375961 is a reply to message #375958] |
Tue, 20 February 2007 14:39  |
Sven Efftinge Messages: 1668 Registered: July 2009 |
Just ignore the warnings, they have nothing to do with your grammar.
The built-in lexer rule for strings is responsible for those warnings.
Unfortunately I don't know how to suppress them... :-(
Sven
> Entity :
> "entity" name=ID;
> Randy Simons
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
| Re: xText Startup Questions [message #562666 is a reply to message #375958] |
Sven
> Entity :
> "entity" name=ID;
> Randy Simons
FUDForum. Page generated in 0.03375 seconds
