Home » Modeling » GMT (Generative Modeling Technologies) » [oaw] type.name empty for uml::PrimitiveType
[oaw] type.name empty for uml::PrimitiveType [message #375653] Wed, 08 November 2006 11:58
Eclipse User
Originally posted by: tobiasbuhr.gmx.de
I have got a Problem with a M2M transformation in oaw.
My Meta-model is: <org.eclipse.uml2.uml/model/UML.ecore>
Via load resource, in the generated editor, I loaded
< org.eclipse.uml2.uml.resources/libraries/JavaPrimitiveTypes. library.uml >
and changed the type of a property to boolean, for example.
Then I want to transform it in oaw (xtend-component) using its name
(PrimitiveType extends uml::type and thus should have a name), but when
I use it, it is always empty.
Here is the snippet:
MyObject newMyObject(uml::PrimitiveType pt):
let o = new MyObject:
// o.setName("Test") ->
// o.setName(pt.toString()) ->
t.setName(pt.name)) ->
t;
If I use "Test" or pt.toString, the value will be set correctly, but
just pt.name is always empty.
pt.toString yields:
org.eclipse.uml2.uml.internal.impl.PrimitiveTypeImpl@1049d3 (eProxyURI:
platform:/resource/org.eclipse.uml2.uml.resources/libraries/ JavaPrimitiveTypes.library.uml#boolean
so it really seems to be a PrimitiveType.
For any ideas, why PrimitiveType.name always is emtpty, I would be very
thankful.
For solution I tried to follow
< http://www.eclipse.org/gmt/oaw/doc/4.1/r50_uml2AdapterRefere nce.pdf>
(don't know if it helps.. :-))
but when I try to invoke the profile
<org.eclipes.uml2.uml/resources:profiles/Ecore.profile.uml>
(UML setup works fine <bean
class="org.openarchitectureware.uml2.Setup"/> :-))
like this:
<metaModel id="profile_java"
class="org.openarchitectureware.uml2.profile.ProfileMetaModel ">
<profile value="profiles/Ecore.profile.uml2"/>
</metaModel>
it yields the error:
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Package
with uri 'http://www.eclipse.org/uml2/schemas/Ecore/3' not found.
Best regards, Tobias
Previous Topic:[ATL] is ATL statically typed?
Next Topic:[oaw] type.name empty for uml::PrimitiveType
Current Time: Wed May 22 04:33:21 EDT 2013
Powered by FUDForum. Page generated in 0.02065 seconds
