Home » Eclipse Projects » DSDP - Target Management » The RSE org.eclipse.rse.importexport plugin execution environments level?
| The RSE org.eclipse.rse.importexport plugin execution environments level? [message #37201] |
Wed, 08 July 2009 07:09  |
Originally posted by: wangqs_eclipse.yahoo.com
I got the latest release of RSE, ie. the RSE-SDK-3.1.zip.
When I click the Review/Synchronize option on the Remote file system
import wizard, I got following errors. Looks the code is not compiled
with Java 1.5 level? I tried the code from head and it works all right.
Can anyone give me an idea of this?
java.lang.Error: Unresolved compilation problems:
Syntax error, parameterized types are only available if source level is 1.5
Syntax error, 'for each' statements are only available if source level
is 1.5
Can only iterate over an array or an instance of java.lang.Iterable
org.eclipse.rse.internal.synchronize.SynchronizeData.<init>(SynchronizeData.java:38)
org.eclipse.rse.internal.importexport.files.RemoteImportWiza rdPage1.finish(RemoteImportWizardPage1.java:675)
org.eclipse.rse.internal.importexport.files.RemoteImportWiza rd.performFinish(RemoteImportWizard.java:121)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:752)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:373)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:624)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:228)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3880)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3473)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
org.eclipse.ui.internal.handlers.WizardHandler$Import.execut eHandler(WizardHandler.java:146)
org.eclipse.ui.internal.handlers.WizardHandler.execute(Wizar dHandler.java:273)
org.eclipse.ui.internal.handlers.HandlerProxy.execute(Handle rProxy.java:294)
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:476)
org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:508)
org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:169)
org.eclipse.ui.internal.handlers.SlaveHandlerService.execute Command(SlaveHandlerService.java:241)
org.eclipse.ui.internal.actions.CommandAction.runWithEvent(C ommandAction.java:157)
org.eclipse.ui.internal.actions.CommandAction.run(CommandAct ion.java:171)
org.eclipse.ui.actions.ImportResourcesAction.run(ImportResou rcesAction.java:97)
org.eclipse.ui.actions.BaseSelectionListenerAction.runWithEv ent(BaseSelectionListenerAction.java:168)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:584)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:501)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
| Re: The RSE org.eclipse.rse.importexport plugin execution environments level? [message #37336 is a reply to message #37201] |
Thu, 09 July 2009 12:19   |
Martin Oberhuber Messages: 967 Registered: July 2009 |
Hello Qwang,
In the problematic case, how did you get the source? The code was
always correct in CVS, it looks like the way how you import / create
the source out of your download results in an invalid .classpath file.
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
qwang wrote:
> Hi
> is 1.5
> is 1.5
> is 1.5
> is 1.5
> level is 1.5
> is 1.5
> is 1.5
> is 1.5
> is 1.5
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
| Re: The RSE org.eclipse.rse.importexport plugin execution environments level? [message #37371 is a reply to message #37336] |
Fri, 10 July 2009 01:08   |
Hi Martin,
Thanks for reply.
The error happened with the binary package which I downloaded the
official release from eclipse website,ie. the RSE-SDK-3.1.zip.
Yes, the source looks correct. When I tried to run against source code,
it works all right.
To make it clear, the RSE installation from RSE-SDK-3.1.zip caused the
problem. Not the source code.
Cheers
Qiangsheng
Martin Oberhuber wrote:
> Hello Qwang,
> Cheers,
> qwang wrote:
>> Hi
>> level is 1.5
>> level is 1.5
>> level is 1.5
>> level is 1.5
>> level is 1.5
>> level is 1.5
>> level is 1.5
>> level is 1.5
>> level is 1.5
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
| Re: The RSE org.eclipse.rse.importexport plugin execution environments level? [message #37473 is a reply to message #37371] |
Thu, 16 July 2009 16:55  |
This problem is now fixed, see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=283482
Thanks for the report!
qwang wrote:
> Hi Martin,
> Thanks for reply.
> it works all right.
> Cheers
> Qiangsheng
>> Hello Qwang,
>> Cheers,
>> qwang wrote:
>>> Hi
>>> level is 1.5
>>> level is 1.5
>>> level is 1.5
>>> level is 1.5
>>> level is 1.5
>>> level is 1.5
>>> level is 1.5
>>> level is 1.5
>>> level is 1.5
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
| Re: The RSE org.eclipse.rse.importexport plugin execution environments level? [message #581935 is a reply to message #37201] |
Hello Qwang,
qwang wrote:
> Hi
> is 1.5
> is 1.5
> is 1.5
> is 1.5
> level is 1.5
> is 1.5
> is 1.5
> is 1.5
> is 1.5
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
| Re: The RSE org.eclipse.rse.importexport plugin execution environments level? [message #581952 is a reply to message #37336] |
Qiangsheng Wang Messages: 5 Registered: February 2010 |
Junior Member |
Hi Martin,
Thanks for reply.
it works all right.
Cheers
Qiangsheng
> Hello Qwang,
> Cheers,
> qwang wrote:
>> Hi
>> level is 1.5
>> level is 1.5
>> level is 1.5
>> level is 1.5
>> level is 1.5
>> level is 1.5
>> level is 1.5
>> level is 1.5
>> level is 1.5
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Q.S.Wang
http://www.myeclipsedev.com
| Re: The RSE org.eclipse.rse.importexport plugin execution environments level? [message #582016 is a reply to message #37371] |
qwang wrote:
> Hi Martin,
> Thanks for reply.
> it works all right.
> Cheers
> Qiangsheng
>> Hello Qwang,
>> Cheers,
>> qwang wrote:
>>> Hi
>>> level is 1.5
>>> level is 1.5
>>> level is 1.5
>>> level is 1.5
>>> level is 1.5
>>> level is 1.5
>>> level is 1.5
>>> level is 1.5
>>> level is 1.5
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
Current Time: Sun May 19 17:28:21 EDT 2013
Powered by FUDForum. Page generated in 0.01831 seconds
