| What do these errors mean? [message #374505] |
Mon, 21 January 2008 05:00  |
Originally posted by: freshon.gmail.com
I'm modifying B2J Engine to weave AspectJ.
By the way, I saw these errors.
C:\Documents and Settings\In Seon Son\Local
Settings\Temp\B2jEngineDependency_58710.jar
file:/C:/Documents and Settings/In Seon Son/Local
Settings/Temp/B2jEngineDependency_58710.jar
Settings\Temp\B2jEngineDependency_58711.jar
Settings/Temp/B2jEngineDependency_58711.jar
Settings\Temp\B2jEngineDependency_58712.jar
Settings/Temp/B2jEngineDependency_58712.jar
Settings\Temp\B2jEngineDependency_58713.jar
Settings/Temp/B2jEngineDependency_58713.jar
java.lang.reflect.InvocationTargetException
org.eclipse.stp.b2j.core.jengine.internal.core.Runner.run(Ru nner.java:230)
Caused by: java.lang.NoClassDefFoundError:
org/aspectj/lang/NoAspectBoundException
JEngineProgram_20080121183815765.activity3(JEngineProgram_20 080121183815765.java:996)
JEngineProgram_20080121183815765.activity1(JEngineProgram_20 080121183815765.java:954)
JEngineProgram_20080121183815765.engine_main(JEngineProgram_ 20080121183815765.java:43)
... 5 more
E:(JEngine (mini) Runner Thread (ID:
0000000000000001)):org.eclipse.stp.b2j.core.jengine.internal .core.Runner.run(Runner.java:238):JEngine
(mini) Runner Thread (ID: 0000000000000001) failed
runner JEngineProgram_20080121183815765.engine_main started (ALIVE)
runner(1)@localhost:BPEL **new thread - bpel process (file: (Final BPEL
Source), line: 2)**: java.lang.NoClassDefFoundError:
java.lang.NoClassDefFoundError: org/aspectj/lang/NoAspectBoundException
How can I fix these errors?
I really want to find fixing these.
Thank you for your reading to end.
| Re: What do these errors mean? [message #374510 is a reply to message #374505] |
Wed, 23 January 2008 10:37   |
Originally posted by: antony.scapatech.com
Hi Seon,
It appears that the B2J engine is trying and failing to load
org.aspectj.lang classes.
B2J has not been tested with AspectJ so I cannot help you with how you
might fix that error.
If you use a Launch Configuration then you can add additional JARs to
the classpath of a particular execution.
thanks
Antony
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> ... 5 more
> at
> at
> at
> at
> at
> at
| Re: What do these errors mean? [message #374519 is a reply to message #374505] |
Wed, 06 February 2008 16:45  |
Originally posted by: ohurley.iona.com
I've cut a bit of your stack trace to make it a little bit
easier to read! What I get from the trace is that the runner
is having a problem finding the AspectJ classes when it is
starting. If you are using the Eclipse launcher mechanisms
then it might be necessary to use the AspectJ/Java Application
specific launcher?
> at
java:996)
> at
java:954)
> at
5.java:43)
> at
> at
..java:25)
> at
Oisin Hurley at IONA
http://blogs.iona.com/ohurley/
| Re: What do these errors mean? [message #610561 is a reply to message #374505] |
Antony Miguel Messages: 49 Registered: July 2009 |
Member |
Hi Seon,
thanks
Antony
> at
> at
> at
> at
> at
> at
> ... 5 more
> at
> at
> at
> at
> at
> at
| Re: What do these errors mean? [message #610570 is a reply to message #374505] |
Oisin Hurley Messages: 204 Registered: July 2009 |
specific launcher?
> at
java:996)
> at
java:954)
> at
5.java:43)
> at
> at
..java:25)
> at
FUDForum. Page generated in 0.05650 seconds
