Home » Eclipse Projects » Service Oriented Architecture Tools Platform (STP) » Re: BPMN Diagram orientation
Re: BPMN Diagram orientation [message #374503] Sun, 20 January 2008 22:47 Go to next message
Eclipse User
Originally posted by: ymo.noemail.com
Hi Antoine.
i tried to check out the stp projects and open them all in eclipse. I am
wondering :
1) after checking out the latest org.eclipse.stp.bpmn* projects from svn
and opening them all in eclipse PoolPoolXYLayoutEditPolicy is still MIA
(missing In Action). I cant get a hold of it. Where is it ?
2) How do i build the jar files and drop them in eclipse ? BAsically how
does the build system is supposed to work
3)How do you test/debug it ?
4) i know the model can be annotated. You already told me that. But i cant
for the life of me figure where i can add annotations. I want the
annotations to be hard coded (static) for now. No need for on the fly
fancy generation .
I tried to read http://wiki.eclipse.org/index.php/Reusing_the_modeler but
it does not cover it adequately.
Re: BPMN Diagram orientation [message #374504 is a reply to message #374503] Mon, 21 January 2008 04:48 Go to previous message
Eclipse User
Originally posted by: atoulme.intalio.com
ymo wrote:
> Hi Antoine.
> wondering :
It's here:
http://dev.eclipse.org/svnroot/stp/trunk/org.eclipse.stp.bpm n/org.eclipse.stp.bpmn.diagram/customsrc/org/eclipse/stp/bpm n/policies/PoolPoolCompartmentXYLayoutEditPolicy.java
There is no build system. You do not need to build and jarify the bpmn
plugins to run them. I would rather advise you to setup a classic
Eclipse installation, install GMF, GEF and EMF using the update site.
Then add them to your workspace as Java projects.
You can then run a new Eclipse instance.
See 2)
> cant for the life of me figure where i can add annotations. I want the
> fancy generation .
You can annotate any EModelElement with EcoreUtil.setAnnotation.
I don't understand what you mean by hard coded here, I guess you want to
have annotations added on creation. In that case just go and override
the PoolPoolCompartmentItemSemanticEditPolicy.
It's located here:
org.eclipse.stp.bpmn.diagram/src/org/eclipse/stp/bpmn/diagra m/edit/policies/PoolPoolCompartmentItemSemanticEditPolicy.ja va
You will need to do the same thing for the sub process compartment edit
policy.
> but it does not cover it adequately.
If you'd like to modify those wiki pages so that they cover more things,
please feel free to do so.
Antoine
Intalio, the Open Source BPMS Company
<a href="http://www.intalio.com">http://www.intalio.com</a>
<a href="http://bpms.intalio.com">Community website</a>
Re: BPMN Diagram orientation [message #610554 is a reply to message #374503] Mon, 21 January 2008 04:48 Go to previous message
Eclipse User
ymo wrote:
> Hi Antoine.
> wondering :
It's here:
See 2)
> fancy generation .
It's located here:
policy.
Antoine
Previous Topic:BPMN Diagram orientation
Next Topic:What do these errors mean?
Current Time: Sun May 19 11:29:38 EDT 2013
Powered by FUDForum. Page generated in 0.01694 seconds
