Home » Eclipse Projects » Service Oriented Architecture Tools Platform (STP) » Could i use B2J stand alone?
Could i use B2J stand alone? [message #374079] Fri, 08 June 2007 05:09 Go to next message
Eclipse User
Originally posted by: mikecy.gmail.com
Hi, friends,
I had installed B2J plug-in with Eclipse 3.3, and I have two question:
1. I can run BPEL which it is included in 'Sample BPEL files', but i can
not run BPEL process which it was created by ActiveBPEL. What's the reason
of this? Does B2J just support pure BPEL? (ActiveBPEL has some extension
points for BPEL).
2. So far, I just run BPEL using B2J with Eclipse, could i use B2J stand
alone without Eclipse?
Thanks.
Mike
Re: Could i use B2J stand alone? [message #374327 is a reply to message #374079] Wed, 24 October 2007 08:18 Go to previous messageGo to next message
Eclipse User
Originally posted by: antony.scapatech.com
Hi Mike,
B2J and ActiveBPEL are likely not on exactly the same page regarding the
BPEL 2.0 specification. The specification has only recently been
ratified and B2J is not completely up to date.
B2J can be run standalone. You can run a BPEL process in the
distributed engine by changing the settings in the launch configuration
(see the 'Distribution' tab). This will mean the process will run
entirely separately from Eclipse.
In addition you can also use the B2J APIs to compile and run BPEL
entirely outwith Eclipse. To do this take a look at the class:
org.eclipse.stp.b2j.core.publicapi.example.IndependantAPIExa mple
in the B2J source code.
cheers
Antony
Mike wrote:
> Hi, friends,
> reason of this? Does B2J just support pure BPEL? (ActiveBPEL has some
> extension points for BPEL).
> Thanks.
> Best regards,
> Mike
Re: Could i use B2J stand alone? [message #601190 is a reply to message #374079] Wed, 24 October 2007 08:18 Go to previous messageGo to next message
Antony Miguel is currently offline Antony Miguel
Member
Hi Mike,
cheers
Antony
Mike wrote:
> Hi, friends,
> Thanks.
> Best regards,
> Mike
Re: Could i use B2J stand alone? [message #1010209 is a reply to message #374327] Sat, 16 February 2013 17:17 Go to previous message
GAALOUL Haithem is currently offline GAALOUL Haithem
please there are an tutorial "B2J Beginners Tutorial (How to run BPEL using B2J)" i don't found it in the net, some one can help me???
or someone have a tuto how to use the b2j plugin of eclipse!!!
help me please, thanks
Previous Topic:UI Rendering for policy values in Policy Editor
Next Topic:BPEL to JAVA
Current Time: Tue May 21 15:08:09 EDT 2013
Powered by FUDForum. Page generated in 0.01690 seconds
