Home » Eclipse Projects » Service Oriented Architecture Tools Platform (STP) » Re: [stp-newsgroup] xalan dependency
| Re: [stp-newsgroup] xalan dependency [message #374029] |
Thu, 06 July 2006 10:19 |
Sebastian Carbajales Messages: 4 Registered: July 2009 |
Junior Member |
This is a multipart message in MIME format.
--=_alternative 004ECAC1852571A3_=
Content-Type: text/plain; charset="US-ASCII"
Hi David,
It turns out that the JREs I checked where issued by IBM which include
this QName class in the xml.jar. So, we've examined our code a little
closer and determined that the class is only used internally. As a result
we will remove this dependency shortly. I will let you know when this is
done.
Sebastian Carbajales, P.Eng
Advisory Software Engineer, Business Integration Tooling
IBM Canada Ltd.
8200 Warden Avenue D3/KWF
Markham, Ontario, L6G 1C7
E-mail: sebastia@ca.ibm.com
Phone: (905) 413-2577
TieLine: 969-2577
David Black <david.black@capeclear.com>
Sent by: stp-newsgroup-bounces@eclipse.org
07/05/2006 12:46 PM
Please respond to
"Gateway between eclipse.stp and stp-newsgroup"
<stp-newsgroup@eclipse.org>
To
cc
Subject
Hi Sebastian,
Thanks for the reply.
In JDK/JRE 1.4.2 xalan is included in the rt.jar. I am actually using 1.5
(precisely: 1.5.0_06) to run Eclipse and compile against (but with 1.4
compliance
level), and there it is not included in rt.jar. A quick look through other
jars and I don't see it. Hmm, has it been moved/removed in 1.5 ?
regards
David
> Hi David,
> Yes, the dependency on org.apache.xml.utils.QName is needed. I am
> not sure what this class was introduced but it is part of Xalan 2.7.0
> which is included in the supported JRE's (1.4.2 or later). What JRE
> have you installed?
> 07/03/2006 03:12 AM
> Please respond to
> To
> cc
> Subject
> (apologies if anyone has already received this via the mailing lists,
> its not clear to be whether those lists are currently in use)
> I've just grabbed the latest stp code from
> dev.eclipse.org:/cvsroot/stp, loaded the various projects into
> Eclipse 3.2 (callisto rc7). I'm seeing a few build errors, including:
> org.apache.xml.utils.QName cannot be resolved to a type
> in the org.eclipse.stp.core.saf.ui plugin. Is this supposed to be in
> there? If so, which version of xalan is being used, am I missing a
> plugin?
> thanks
> David Black
> Cape Clear Software
> _______________________________________________
> stp-newsgroup mailing list
> https://dev.eclipse.org/mailman/listinfo/stp-newsgroup
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Hi David,</font>
<br>
<br><font size=2 face="sans-serif">It turns out that the JREs I checked
where issued by IBM which include this QName class in the xml.jar. So,
we've examined our code a little closer and determined that the class is
only used internally. As a result we will remove this dependency
shortly. I will let you know when this is done.</font>
<br><font size=2 face="sans-serif"><br>
Regards,<br>
<br>
Sebastian Carbajales, P.Eng<br>
------------------------------------------------------------ ------------------ <br>
Advisory Software Engineer, Business Integration Tooling <br>
IBM Canada Ltd.<br>
8200 Warden Avenue D3/KWF<br>
Markham, Ontario, L6G 1C7<br>
<br>
E-mail: sebastia@ca.ibm.com<br>
Phone: (905) 413-2577<br>
TieLine: 969-2577<br>
------------------------------------------------------------ ------------------ </font>
<br>
<br>
<br>
<table width=100%>
<tr valign=top>
<td width=40%><font size=1 face="sans-serif"><b>David Black <david.black@capeclear.com></b>
</font>
<br><font size=1 face="sans-serif">Sent by: stp-newsgroup-bounces@eclipse.org</font>
<p><font size=1 face="sans-serif">07/05/2006 12:46 PM</font>
<table border>
<tr valign=top>
<td bgcolor=white>
<div align=center><font size=1 face="sans-serif">Please respond to<br>
"Gateway between eclipse.stp and stp-newsgroup" <stp-newsgroup@eclipse.org></font></div></table>
<br>
<td width=59%>
<table width=100%>
<tr valign=top>
<td>
<div align=right><font size=1 face="sans-serif">To</font></div>
<td><font size=1 face="sans-serif">stp-newsgroup@eclipse.org</font>
<tr valign=top>
<td>
<div align=right><font size=1 face="sans-serif">cc</font></div>
<td>
<tr valign=top>
<td>
<div align=right><font size=1 face="sans-serif">Subject</font></div>
<td><font size=1 face="sans-serif">Re: [stp-newsgroup] xalan dependency</font></table>
<br>
<table>
<tr valign=top>
<td>
<td></table>
<br></table>
<br>
<br>
<br><tt><font size=2>Hi Sebastian,<br>
<br>
Thanks for the reply.<br>
<br>
<br>
compliance <br>
<br>
jars and I don't see it. Hmm, has it been moved/removed in 1.5 ? <br>
<br>
regards<br>
David<br>
<br>
> Hi David,<br>
> <br>
I am<br>
> not sure what this class was introduced but it is part of Xalan 2.7.0<br>
JRE<br>
> have you installed?<br>
> <br>
> Regards,<br>
> <br>
> Sebastian Carbajales<br>
> <br>
> David Black <david.black@capeclear.com><br>
> Sent by: stp-newsgroup-bounces@eclipse.org<br>
> 07/03/2006 03:12 AM<br>
> "Gateway between eclipse.stp and stp-newsgroup"<br>
> <stp-newsgroup@eclipse.org><br>
> To<br>
> stp-newsgroup@eclipse.org<br>
> cc<br>
> Subject<br>
> [stp-newsgroup] xalan dependency<br>
> Hi,<br>
> <br>
> (apologies if anyone has already received this via the mailing lists,<br>
> its not clear to be whether those lists are currently in use)<br>
> <br>
> I've just grabbed the latest stp code from<br>
> dev.eclipse.org:/cvsroot/stp, loaded the various projects into<br>
> Eclipse 3.2 (callisto rc7). I'm seeing a few build errors, including:<br>
> <br>
> org.apache.xml.utils.QName cannot be resolved to a type<br>
> <br>
in<br>
> there? If so, which version of xalan is being used, am I missing a<br>
> plugin?<br>
> <br>
> thanks<br>
> <br>
> ---------------------------------------<br>
> David Black<br>
> Cape Clear Software<br>
> _______________________________________________<br>
> stp-newsgroup mailing list<br>
> https://dev.eclipse.org/mailman/listinfo/stp-newsgroup<br>
<br>
<br>
</font></tt>
<br>
--=_alternative 004ECAC1852571A3_=--
Current Time: Sun May 19 23:02:46 EDT 2013
Powered by FUDForum. Page generated in 0.01465 seconds
