Home » Archived » OHF » creating a top down web service with eclipse
creating a top down web service with eclipse [message #36726] Fri, 09 November 2007 11:47
Massimo Tivoli is currently offline Massimo Tivoli
as for some of you, I am trying to create a first web service from a
..wsdl definition.
I am following "the top down web services" tutorial.
At generation time, the wizard give me the error reported below. I am
using Apache Tomcat v6.0,
Axis2 v1.3, Eclispe Europa v3.3.1, WTP v1.1.1, and Java 5. Do you have
experienced a similar problem
before? Some suggestion to solve it?
Thank all in advance,
-Massimo.
Exception occurred while code generation for the WSDL :
java.lang.AbstractMethodError:
org.apache.xerces.dom.DeferredDocumentImpl.getInputEncoding( )Ljava/lang/String;
java.lang.reflect.InvocationTargetException
org.eclipse.jst.ws.axis2.consumption.core.utils.WSDL2JavaGen erator.getAxisService(WSDL2JavaGenerator.java:379)
org.eclipse.jst.ws.axis2.creation.core.command.Axis2WSDL2Jav aCommand.execute(Axis2WSDL2JavaCommand.java:80)
org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.runCommand(CommandFragmentEngine.java:419)
org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.visitTop(CommandFragmentEngine.java:359)
org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.moveForwardToNextStop(CommandFragmentEngine.jav a:254)
org.eclipse.wst.command.internal.env.ui.widgets.SimpleComman dEngineManager$6.run(SimpleCommandEngineManager.java:294)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:369)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:313)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 934)
org.eclipse.wst.command.internal.env.ui.widgets.SimpleComman dEngineManager.runForwardToNextStop(SimpleCommandEngineManag er.java:264)
org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.runForwardToNextStop(WizardPageManager.java:91)
org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.getNextPage(WizardPageManager.java:154)
org.eclipse.wst.command.internal.env.ui.widgets.SimpleWizard Page.getNextPage(SimpleWizardPage.java:136)
org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:813)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:369)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:616)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:227)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1495)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1519)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1504)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1 295)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3350)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2954)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
at org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:182)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:546)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
Caused by: java.lang.AbstractMethodError:
org.apache.ws.commons.schema.utils.DOMUtil.getInputEncoding( DOMUtil.java:594)
org.apache.ws.commons.schema.XmlSchemaCollection.read(XmlSch emaCollection.java:348)
org.apache.axis2.description.WSDLToAxisServiceBuilder.getXML Schema(WSDLToAxisServiceBuilder.java:140)
org.apache.axis2.description.WSDL11ToAxisServiceBuilder.copy ExtensibleElements(WSDL11ToAxisServiceBuilder.java:2186)
org.apache.axis2.description.WSDL11ToAxisServiceBuilder.proc essTypes(WSDL11ToAxisServiceBuilder.java:306)
org.apache.axis2.description.WSDL11ToAxisServiceBuilder.proc essTypes(WSDL11ToAxisServiceBuilder.java:297)
org.apache.axis2.description.WSDL11ToAxisServiceBuilder.popu lateService(WSDL11ToAxisServiceBuilder.java:265)
... 62 more
Previous Topic:creating a top down web service with eclipse
Next Topic:confidentiality code when submitting CDA works strangely
Current Time: Sat May 25 20:35:36 EDT 2013
Powered by FUDForum. Page generated in 0.01576 seconds
